VXDIAG VCX NANO
satria_wr
Vehicle: 2014 Ford Ecosport 1.5L Ti-VCT 110hp
Re: VXDIAG VCX NANO
Post by satria_wr » Thu Apr 07, 2016 9:27 am
Automate wrote:
Yoda wrote:It didn't find as many modules as my Vlink adapter does
Doesn't the VCX NANO support MS-CAN? Why does it not find all the modules?
I believe the VCX Nano support MS-CAN.
Here is the spec:
Accord with SAE-J2534
*Fully compatible with SAE-J2534-1 & SAE-J2534-2.
*Online ECU diagnosis and reprogramming. The same as
the original tool.
*High comparison of price and function, repeat to use,
Support with third party and OEM diagnostic application
which was compatible with J2534.
PC Interface
*Support USB2.0 high speed connection.
*Support Bluetooth2.0 wireless connection.
*Provide PC configuration tool, detect connection
automatically, update firmware automatically.
Vehicle Interface
*Hardware integrated as J-1962 OBD-II connector, connect with vehicles without cable.
*Support the folowing protocols:
ISO9141(K-Line)
ISO14230-2(K-Line)
ISO15765(CAN)
SAE-J1850 PWM(Ford SCP)
SAE-J1850 VPW(GM Class2)
Single Wire CAN(GMLAN)
*Support 4 CAN, 3 High Speed CAN and Single Wire CAN.
*Programming voltage: 5V~20V FEPs output.
*Support multi-channels work continuously, for example: 2 wire CAN or K-Line work at same time.
*Large memory to increase date throughput, 32KByte can be reached by single transfer
2014 Ford Ecosport Titanium
1.5 Ti-VCT Sigma (Remapped using PCMFlash)
PowerShift
2016 Mitsubishi Pajero Sport Limited
2.4 4N15 DiD (Remapped using New Genius)
8-A/T
Automate
Re: VXDIAG VCX NANO
Post by Automate » Sat Jun 11, 2016 1:23 pm
Yoda wrote:Couldn't figure out how to get WiFi working on it, so I installed the driver
for USB and used USB instead.
The AllScanner site only lists working with Bluetooth and USB not WiFi
http://www.allscanner.com/?page_id=9206&lang=en
Yoda wrote: Forscan detected it as J2534, and no errors was reported.
It didn't find as many modules as my Vlink adapter does,
I think I saw something in the FORScan change log about fixing this. The VCX found all the HS and MS modules on my Fusion
Automate
Re: VXDIAG VCX NANO
Post by Automate » Sat Jun 11, 2016 1:29 pm
Got FORScan working with it using the USB cable, even on Windows 10. It gets 1ms min timing versus 7 to 10ms for my OBDLink MX Bluetooth.
The blue light blinks on the VCX but I'm not able to pair with Bluetooth. Anyone get Bluetooth to work?
stvkram
Vehicle: 2003 Mazda 6 3.0 V6 220hp
Re: VXDIAG VCX NANO
Post by stvkram » Sat Jun 11, 2016 7:19 pm
I can add that regarding the VCX Nano for ford/mazda, I took mine apart and no bluetooth module is present. The bluetooth capabilities advertised on the main Allscanner site it not accurate. I can not speak for the WIFI version but I have the usb version and have used it with my 2003 Mazda 6 V6 and AFTER installing the "pass-thru" driver (J2534) it works perfectly and fast with FORSCAN.
Automate
Re: VXDIAG VCX NANO
Post by Automate » Sat Jun 11, 2016 7:48 pm
stvkram wrote:I took mine apart and no bluetooth module is present.
How did you get it open? I don't see any screws.
Did you happen to take any pics of the inside? Some blogs have complained about the poor solder quality on some of the VCM2 clones.
stvkram
Re: VXDIAG VCX NANO
Post by stvkram » Sat Jun 11, 2016 9:56 pm
The VCX Nano I took apart seems to be a custom design to emulate in hardware part of the hardware/software of the VCM II but the driver is most important too. I did not take pictures but gently peeling down the stickers reveals 4 screws. Once inside it is a very simple board with a ST micro cortex M4 STM32F4 Series based micro controller doing the work. The FT serial to usb chip-set and some caps and a space that was blank for I assume either the WIFI or Bluetooth module. I googled the device and did see a Russian site where a guy took apart a VW version and it had more chips and and older generation micro-controller.
Soldering looks like reasonable quality surface mount and no hand work or redo's.
satria_wr
Re: VXDIAG VCX NANO
Post by satria_wr » Mon Aug 01, 2016 4:37 am
I test this tool, i buy the wifi version. Ford/GM/Toyota/VW/JagLR all works with wifi or usb connection :D
PowerShift
8-A/T
Revolter
Vehicle: 2013 c-max
Re: VXDIAG VCX NANO
Post by Revolter » Mon Aug 08, 2016 6:35 pm
Hi, I have got the VCX nano, unfortunately I can't get FORScan to work with it, it finds it but not connecting to my car which is ON. I have proximity key, no manual key and it is in the car, tried also have car runnning but no change, can anyone tell me how to set FORScan to detect and work with VCX nano?
Drazick
Vehicle: Mazda CX-5 F/L
Re: VXDIAG VCX NANO
Post by Drazick » Mon Aug 08, 2016 9:51 pm
Revolter wrote:Hi, I have got the VCX nano, unfortunately I can't get FORScan to work with it, it finds it but not connecting to my car which is ON. I have proximity key, no manual key and it is in the car, tried also have car runnning but no change, can anyone tell me how to set FORScan to detect and work with VCX nano?
First of all install VCXManager and this driver:
And second configure ForScan how this image:
Its run perfectly
Update your VCXmanager and drivers to the lastest version
Revolter
Vehicle: 2013 c-max
Re: VXDIAG VCX NANO
Post by Revolter » Sat Aug 13, 2016 6:13 pm
Thank you for info, do you happen to know how to add smart proximity key ? I have only one existing proximity key and can't use Ford procedure for owners. I have IDS, FORScan and VCX, can this be used to add smart proximity key ?
