Ford Fiesta 2004 trouble code
joshBE
Vehicle: ford fiesta
Post by joshBE »
Hello
I bought a ford fiesta 1.3 from 2004 a couple a day's ago,
Now tgoday the engine check light came up and i read it out with Forscan with elm.
Now this is the trouble code i get,
PCM - Powertrain Control Module. P0130-E0 HO2S11 circuit malfunction.
OBDII - On Board Diagnostic II. P0130-C H02S11 circuit malfunction.
can somebody help what this trouble code means?
Thanks in advance!!
WALK3R
Vehicle: Ford Trasit 2012
Re: Ford Fiesta 2004 trouble code
Post by WALK3R »
joshBE wrote:
Tue May 21, 2019 1:36 pm
Hello
Thanks in advance!!
it's probably a bad o2 (Lambda) sensor
joshBE
Post by joshBE »
WALK3R wrote:
Tue May 21, 2019 2:04 pm
Thanks gonna look for it,
When i started my engine the Check Engine Light was gone,
But when i read it out again it was still logged and then i removed it and then this code came up,
===PCM DTC P1000-70=== ( this time i read it out with my laptop with forscan )
Do you know what that means? with the code there is a lot of text that explains this code but i dont understand it enough.
This is a part of the text : P1000 cannot be cleared from the PCM when: 1. The thermostat is stuck open and a DTC is not generated. 2. There is an open VSS circuit and a DTC is not generated. 3. If the vehicle has a Power Take Off (PTO), the circuit is shorted to VPWR or B+, or the PTO is ON during Self-test.
Sorry for the many and maybe dumb questions.
Greetings Josh
WALK3R
Post by WALK3R »
You can ignore P1000, normally means DTCs have been cleared or a test wasn't completed fully
joshBE
Post by joshBE »
WALK3R wrote:
Tue May 21, 2019 5:18 pm
Okay thanks :)
