Dpf regen wont work
jpq
Vehicle: c max 2015 1.6 tdci
Dpf regen wont work
Post by jpq » Thu May 16, 2019 3:30 pm
Hi any reasons for dpf regen not to work on a 1.6 tdci eco 2013 year cheers Jake
denbo
Vehicle: ford focus 16 zetec
Re: Dpf regen wont work
Post by denbo » Fri May 17, 2019 3:53 pm
Many reasons. What did scan tool tell you?
jpq
Post by jpq » Mon May 20, 2019 8:15 am
Hi I had dtcs for dpf pressure to high found fuel vaporiser blocked I then replaced it etc and tried a regen on forscan to no success. I then used ids as I have use of one and went straight in and was successful
WALK3R
Vehicle: Ford Trasit 2012
Post by WALK3R » Mon May 20, 2019 9:52 am
if thats the case then send a debug file to the forscan team so they can look into it
https://forscan.org/contactus.html
