Tire pressure monitor fault Ford Escape 2012
Posted: Thu May 16, 2019 12:34 am
by jcascog86
Hello to all
I have an issue with my escape 2012, I'm driving the car without any problem but sometimes the.little screen on the dash shown tire pressure monitor fault and the light of tpms, door open and emergency brake are on like the picture attached, when this warning appear the other ligth like Hazzard won't works and the AC compressor won't work as well
Re: Tire pressure monitor fault Ford Escape 2012
Posted: Fri May 17, 2019 3:57 pm
by denbo
Did you scan for faults? I would start with a battery check.
Posted: Mon May 27, 2019 1:18 pm
by jcascog86
Yes and i can't see any fault, is there any way to show you a log of the scan?
Which battery? the engine's battery? If this is, I already changed with another one
Posted: Wed May 29, 2019 9:25 pm
by theandies
I was going to say you probably need to relearn the TPMS sensors. Search for how to do it for your model. I just went through this with my 2016 Fusion after enabling the 4-wheel tire pressure screen on my left instrument cluster. But after reading you post and you have other issues that may not be the problem. I agree that your battery may be going. Good luck.
