New Forscan Tutorial for Transit Connect, Tutorials in General
Posted: Tue Apr 09, 2019 11:46 pm
by phollenback
Hi folks, I wanted to disable the approach lights on my 2018 Ford Transit Connect. The dealer couldn't do it, so I decided to try it myself. I found out about Forscan, and I used some existing tutorials to get up to speed (such as the excellent Ford F150 tutorial.
However, I found that tutorial to be lacking in some details, and too focused on the F150, so I went ahead and wrote my own tutorial. I'm sharing it here in the hope that others find it useful.
Thanks!
Re: New Forscan Tutorial for Transit Connect, Tutorials in General
Posted: Wed Jun 26, 2019 5:42 pm
by mbarkley
Your tutorial is very helpful, I have not this option in BdyCM Module configuration, but disabled approach lights in BdyCM Module configuration (AS BUILT format), only changed the code from 726-01-08 0xxx xxxx xxxx to 726-01-08 2xxx xxxx xxxx.
Thanks a lot.
Posted: Mon Aug 12, 2019 5:27 pm
by jrc5900
Hi DO you know if their is a way to make the radio stay on for longer than 30 minutes if the connect is off? It must be in the settings but were?
Jack
