2016 F150 SCREW - FIRST SCAN, need guidance pls!
Infinity99
Vehicle: 2016 f150 3.5eb
Post by Infinity99 » Wed Mar 27, 2019 4:51 am
Hey there folks,
I have a 2016 F150 3.5eb Lariat screw w/502a pkg. I have just scanned my truck using an OBDlink MX (great piece of kit btw) if you can get it to work with Windows 10, HA! But I digress, I have scanned my truck and these are the results. I will state that my truck has intermittent "misfire" on a couple of cylinders that I can not seem to diagnose and the dealership.... well they are the dealership and seem to magically not find anything, ever. So I have taken matters into my own hands!
2 things exist on my truck that are causing issues.
1. random misfires on a couple of cylinders (plugs replaced twice with a .030 gap each time) has always had random misfires.
2. For no reason whatsoever, I get a "hill descent control fault, service advancetrack" warnings with the ABS and traction control warning lights lit up.
For the errors it seems to happen at no specific time. One time I was doing 90 on the highway, the other at a dead stop in traffic. The characteristics of the truck do not change, other than the parking sensors not working. These errors stay illuminated for a few start ups/drives then go away. I will also note that the truck was rear ended, however these errors existed before the accident so please ignore any parking sensor faults.
Please look over the errors and guide me on what \i need to do to address each one. BTW i'm kinda new to the FORScan program, but have used similar scan tools in the past and am very mechanically inclined.
Please see all the codes below and guide me on what is needed to address each one.
THANK YOU IN ADVANCE!
===PCM DTC U0415:00-68===
Code: U0415 - Invalid Data Received from Anti-Lock Brake System (ABS) Control Module A
Status:
- Previously Set DTC - Not Present at Time of Request
- Test not complete
Module: Powertrain Control Module
===END PCM DTC U0415:00-68===
===OBDII DTC None===
Successful DTC reading, no error codes found
Module: On Board Diagnostic II
===END OBDII DTC None===
===APIM DTC None===
Module: Accessory Protocol Interface Module
===END APIM DTC None===
===PAM DTC B1B50:96-2B===
Code: B1B50 - Left Rear Inner Sensor
Additional Fault Symptom:
- Component Internal Failure
Status:
Module: Parking Aid Module
===END PAM DTC B1B50:96-2B===
===BdyCM DTC None===
Module: Body Control Module
===END BdyCM DTC None===
===DACMC DTC None===
Module: Digital Audio Control Module C
===END DACMC DTC None===
===SODR DTC None===
Module: Side Obstacle Detection Control Module - Right
===END SODR DTC None===
===SODL DTC None===
Module: Side Obstacle Detection Control Module - Left
===END SODL DTC None===
===IPMB DTC None===
Module: Image Processing Module B
===END IPMB DTC None===
===FCIM DTC U0155:00-08===
Code: U0155 - Lost Communication With Instrument Panel Cluster (IPC) Control Module
Status:
Module: Front Controls Interface Module
===END FCIM DTC U0155:00-08===
===FCIM DTC U0253:00-08===
Code: U0253 - Lost Communication With Accessory Protocol Interface Module
Status:
===END FCIM DTC U0253:00-08===
===FCIM DTC U0401:82-08===
Code: U0401 - Invalid Data Received from ECM/PCM A
- Alive/Sequence Counter Incorrect/Not Updated
Status:
===END FCIM DTC U0401:82-08===
===FCIM DTC U0452:82-08===
Code: U0452 - Invalid Data Received From Restraints Control Module
Status:
===END FCIM DTC U0452:82-08===
===TRM DTC None===
Module: Trailer Module
===END TRM DTC None===
===DSP DTC None===
Module: (Audio) Digital Signal Processing Module
===END DSP DTC None===
===RBM DTC None===
Module: Running Board Control Module
===END RBM DTC None===
===OCS DTC None===
Module: Occupant Classification System Module
===END OCS DTC None===
===TCCM DTC None===
Module: Transfer Case Control Module
===END TCCM DTC None===
===ABS DTC None===
Module: Antilock braking system
===END ABS DTC None===
===TrlrBM DTC None===
Module: Trailer Brake Control Module
===END TrlrBM DTC None===
===RTM DTC None===
Module: Radio Transceiver Module
===END RTM DTC None===
===PDM DTC None===
Module: Passengers Door Control Unit
===END PDM DTC None===
===DDM DTC U2010:00-08===
Code: U2010 - Switch Illumination
Status:
Module: Drivers Door Module
===END DDM DTC U2010:00-08===
===RCM DTC None===
Module: Restraint Control Module
===END RCM DTC None===
===PSCM DTC U0415:00-08===
Status:
Module: Power Steering Control Module
Freeze Frame :
-STEER_FEEL: Normal - Steering Personalization Status
-STRWHL_POS_CAL: No - Steering Wheel Position Sensor Calibration
-SW_RAW: 11.90 ° - Steering Wheel Angle - Raw
-SW_ANGLE: 0.00 ° - Steering Wheel Angle
-SSHFT_TQ_S2: -1.3 Nm - Steering Shaft Torque Sensor #2
-SW_ALIGN_OFSET: 3276.60 ° - Steering Wheel Angle Alignment Offset
-TOTDIST: 71308.0 km - Total Distance
-GLOBTIM: 83283836 sec - Global real time
-MOD_SUP_V: 13.40 Volt - Module Supply Voltage
-PSCM_INT_TEMP: 28 °C - PSCM Internal Temperature
-EPAS_MOTOR_CUR: 0.60 Amper - EPAS Motor Current
-VSS: 57.0 km/h - Vehicle Speed
===END PSCM DTC U0415:00-08===
===ACM DTC None===
Module: Audio Control Module
===END ACM DTC None===
===SCCM DTC None===
Module: Steering Column Control Module
===END SCCM DTC None===
===IPC DTC None===
Module: Instrument Panel Control Module
===END IPC DTC None===
===GWM DTC None===
Module: Gateway Module A
===END GWM DTC None===
===HSWM DTC None===
Module: Heated Steering Wheel Module
===END HSWM DTC None===
===IPMA DTC None===
Module: Image Processing Module A
===END IPMA DTC None===
===SCME DTC None===
Module: Seat Control Module E
===END SCME DTC None===
===DSM DTC None===
Module: Driver's Seat Module
===END DSM DTC None===
denbo
Vehicle: ford focus 16 zetec
Re: 2016 F150 SCREW - FIRST SCAN, need guidance pls!
Post by denbo » Wed Mar 27, 2019 8:11 pm
Looks like you need to have the ABS module looked at. As for the missfire im sure you will get there soon.
dsbarros
Vehicle: 2015 Ford F150 3.5 Ecoboost
Post by dsbarros » Tue Jun 25, 2019 1:12 pm
About the misfire, you might wanna try replacing the coil boots. They're inexpensive and there was a TSB out saying you should replace the boots with the spark plugs, if you found carbon trekking.
Ignition Issues
If you get a 3.5L EcoBoost in your shop with misfire code(s) P0300-0306, pull the plugs and coil boots and look for carbon tracks on the insulator of the plugs. If any tracking is present, replace all the plugs and boots. See TSB 14-0180 for more information.
