MAF sensor diagnose
Pg502
Vehicle: Mustang, v6, 2011
Re: MAF sensor diagnose
Post by Pg502 » Fri May 24, 2019 11:41 pm
I have, maybe it measures frequency not voltage
TechLuke84
Vehicle: Ford Fiesta Focus Mondeo Kuga
Post by TechLuke84 » Mon May 27, 2019 6:34 pm
The MAF uses frequency (Hz) for the signal. You probably have 3 wires for the sensor, ground, 5V reference and signal. You can check power and ground with a multimeter and ignition on but you’ll need an oscilloscope to check the signal at the sensor. What’s the details of the car, symptoms and fault codes?
Pg502
Post by Pg502 » Mon May 27, 2019 7:17 pm
Using forscan
At idle
MAF is 4g/sec,
MAF hz around 2000
And increases at a constant rate with higher rpms
It’s 2011 mustang v6 with bbk exhaust system (long tube headers, catted h pipe)
Has an af cold air intake. Previous owner install.
The fuel trims are fine at high rpms
But at idle it’s -14 and goes to positive 12 consistently
And rpms are 600-700 at idle. Shakes a little every 5 seconds at idle
When coming to a stop the car sometimes stalls
Or hesitates dropping to 400rpms and going back to avg 600-700 rpms.
No engine codes
No misfires
Throttle body and pcv are fine
TechLuke84
Post by TechLuke84 » Mon May 27, 2019 8:27 pm
Your fuel trim is trying to correct very lean and very rich, have you checked your oxygen sensor readings? Would be interesting to see them.
Pg502
Post by Pg502 » Tue May 28, 2019 3:40 am
I ran forscan today
Fuel trims are in -12 and -14
I wasn’t sure what tab is the o2 sensor
But 02s11impe and 02s21impe (sensor impedance is express as voltage )
Was only .09-.10 in voltage
The 02s22 and o2s12 where both alternating voltage between .1 through .8
Vehicle: *** Ford ***
Post by f-wolf » Tue May 28, 2019 5:56 am
The O2 Sensors look OK
Try cleaning the MAF sensor with MAF sensor cleaner ...
If No change ... you have to get a new MAF Sensor
https://howtune.com/articles/208-clean- ... ustang
TechLuke84
Post by TechLuke84 » Tue May 28, 2019 7:40 pm
Your oxygen sensors look normal, you can try cleaning the maf but if it doesn’t work I wouldn’t just throw a new one at it! You can check the sensor wiring for a 5V reference and check it has a good ground. Do you have an oscilloscope?
Pg502
Post by Pg502 » Tue May 28, 2019 11:40 pm
I tried cleaning the maf sensor, but according to the hz and g/sec of air it seems to be functioning right. I have checked for voltage and ground will a multimeter, I don’t have a Oscilloscope.
The down stream o2 sensors only stay between .09-.1 volts???
Post by f-wolf » Wed May 29, 2019 4:58 am
What voltage should downstream o2 sensor read?
When the air/fuel mixture is balanced or at the equilibrium point of about 14.7 to 1, the sensor will read around 0.45 volts.
TechLuke84
Post by TechLuke84 » Wed May 29, 2019 3:10 pm
Depending on the type of oxygen sensor, they are probably zirconia so the up stream sensors should switch once per second between 0.2v and 0.8v. The downstream will read a steady 0.1v or 0.2v. Expect those readings when the vehicle is in closed loop.
