Ford Mondeo
ahmet0606
Vehicle: 2015 dieseel
Ford Mondeo
Post by ahmet0606 » Sat Feb 09, 2019 2:30 pm
What is the 2017 model ford mondeo handbrake puller and droplet operation sequence. operation when changing the brake pad
yunuska
Vehicle: Ford Mondeo 1.5 Ecoboost 5D 160ps 2015
Re: Ford Mondeo
Post by yunuska » Sun Feb 17, 2019 3:15 pm
1.Turn the start key on position
2.press the acceleration pedal
3.Push down on handbrake button
4.while you hold of those two, cycle the key position off and back it on position again.
5.Then you will see parking brake maintenance mode message. Now you can change brake pads.
To exit maintenance mode same procedure except 3rd step.
3.You push up the handbrake button.
stimpy88
Vehicle: Ford Mondeo Mk4.5 - Diesel 2.0, 163, 2013
Re: Ford Mondeo
Post by stimpy88 » Tue Feb 19, 2019 12:27 pm
On his behalf, and all others your post helps...
THANK YOU!
ahmet0606
Re: Ford Mondeo
Post by ahmet0606 » Sun Apr 07, 2019 7:27 pm
thank s bro
renebo
Vehicle: S-Max 2018 2,0 Ecoboost 240bhp
Re: Ford Mondeo
Post by renebo » Tue Jun 18, 2019 5:42 pm
Hi.
Does anyone know if this procedure is the same on S-max 2018?
Thank you :)
Vehicle: FORD S-Max MK2 2,0TDCi PowerShift
Re: Ford Mondeo
Post by fordsmax471 » Tue Jun 18, 2019 6:23 pm
FORScan includes service function
"Enter Electric Parking Brake Maintenance Mode" and "Exit Electric Parking Brake Maintenance Mode"
ELS27 v4.0 / ELM327 v2.2 HS/MS CAN USB
renebo
Re: Ford Mondeo
Post by renebo » Tue Jun 25, 2019 7:04 pm
Awesome, thank you!
