sylvanus67
Vehicle: Ford Galaxy 2006-2010
Post by sylvanus67 »
tractmec wrote:
Tue May 11, 2021 5:34 pm
This is something you should probably email to Forscan with the Debug information as detailed at the contact page here: https://forscan.org/contactus.html at their email: contact@forscan.org Following the instructions under the Heading:
Providing FORScan Debug information
Afraid I have no other answers for you!
Thanks for a detailed explanation.
I have ordered an another transponder from Aliexpress, I shall try with it. And if it will be unsuccessfull again, I wil give a try for first erasing all keys.
avgs122
Vehicle: Ranger 2.3L 4cyl, 2011
Post by avgs122 »
I have this issue. Everytime I try to program a different cluster (Pats) it just says procedure interrupted. If I put the original cluster in it will let me do anything add keys, module initialization etc.
Rn everytime I do as built configuration on the used cluster it will say it was reset to as built (on forscan) but after I turn the ignition on and off it just goes back to whatever it was before using as built.
Rn with the used cluster I'm getting error B1260-FF (theft detected immobilizing engine) but with original cluster it will start right up.
This is my first post. I just don't know what to do.
Capture (1).PNG (125.89 KiB) Viewed 260 times
stingone
Vehicle: Ford Mondeo, 1.5 duratec, 120HP, 2016
Post by stingone »
and_therex wrote:
Sat Dec 05, 2020 10:55 am
I bought a new remote start key for my mondeo mk5 vehicle in addition to my existing 2 original keys. Now my question is, can I encode this new key as a third key with forscan without deleting one of my other 2 devices?
Where did you bought the key.?
