fordnick
Vehicle: Ford BA Fairmont 2003
Post by fordnick » Tue Mar 05, 2019 12:01 am
:oops: ah yeah
npuBaJIT
Vehicle: Mazda CX5 2,5 GT
Post by npuBaJIT » Sat Mar 09, 2019 1:15 pm
Dear All,
I tryed to find any information but couldn't. Is it possible to program key with Forscan using els27 for Mazda CX5 2018?
Regards,
Max
f-wolf
Vehicle: *** Ford ***
Post by f-wolf » Sat Mar 09, 2019 8:16 pm
This vehicle requires special equipment to be connected to the vehicle to program the keyless remote.
http://www.programyourremote.com/classi ... -9163.aspx
vlntn
Vehicle: Focus 2 facelift 1.6 tdci 109 hp 2009
Post by vlntn » Mon Mar 11, 2019 6:21 pm
Ohhh, Forscan is fantastic! Thank you guys
npuBaJIT
Post by npuBaJIT » Tue Mar 12, 2019 6:34 pm
Dear F-wolf, Could you advise which adapter I could you to programm key for my mazda? Also would be good if this adapter/scanner/programmer could be used as a scanner, like VCM2 for mazda, but a little bit cheaper :)
Best regards,
Max
firemanpek
Vehicle: Px2 diesel 3.2 Ford Ranger 2018
Post by firemanpek » Tue Mar 12, 2019 7:54 pm
Is it possible to program keys for a Ford ranger px2 2018 I would like a 3rd spare, they are around $80 from online locksmith where I have bought good keys for other cars. Thanks, Damien
f-wolf
Post by f-wolf » Wed Mar 13, 2019 12:03 am
Note: Some vehicles, typically 2010+ models and those that use “smart” proximity keys will require professional programming by an Automotive Locksmith.
Have a look / read here:
MAZDA Key Programming Device via OBD II - 2005 - 2018 - M1
(the device includes software only for MAZDA vehicles from 2005 to 2018)
Price: 3500 EUR
https://www.vag-info.com/category/preview/FORD_MAZDA
MAZDA CX5 2017 year key programming
https://www.youtube.com/watch?v=hSosL2pHr1Q
Also:
2018 Mazda CX-5 proximity programming via Smart Pro
https://www.youtube.com/watch?v=xcdCiJIOBOY
f-wolf
Post by f-wolf » Wed Mar 13, 2019 12:48 am
Re, program keys for a Ford ranger px2 2018
Reprogramming an un-coded new key for a current-generation PX (2007-current) Ford Ranger can be done at home if your model is an early 2007-2011 Mark 1 model. You simply get your two original keys, sit in the car with the door closed, and then turn each key to position 2 on the ignition barrel (with the red lights showing on the dash), then remove each within 10 seconds per-key. You then insert the new key, turn it to ignition position 2 and remove it within 10 seconds. You can then re-insert the key and start the car.
However, if you have a later model Ford Ranger you need to have a Ford dealer program the key to your specific car and this cannot be done at home as it involves communicating with the car’s ECU. Different dealers can charge different amounts to supply and code a key, anywhere from $350 to $1500
https://www.carsguide.com.au/car-advice ... -fob-69000
Also have a read here :?: https://www.beachautomotive.com/how-to- ... d-key-fob/
firemanpek
Post by firemanpek » Wed Mar 13, 2019 9:25 am
Thanks f-wolf. I have done similar programing with land cruiser and camrys. I have also used forscan to program keys for bf and ba falcons. I was wondering if anyone had done it with px2 rangers. I'm guessing eventually it will be possible. I'll ask the dealer how much they charge. Thanks, Damien
firemanpek
Post by firemanpek » Mon Mar 18, 2019 7:55 am
I just saw on the ranger mods forum that you can do it if you have 2keys already. Looks like I can, it'll save some cash, good stuff. I'll post the link but it won't work unless you get registered https://www.saeb.net/viewtopic.php?t=568
