Cylinder Balance data. 2008 Ford Galaxy 2.0 Tdci
Posted: Sat Dec 29, 2018 7:38 pm
by Carlng1968
Could someone tell me if this data is normal ? My car has been difficult to start lately even from warm.
Re: Cylinder Balance data. 2008 Ford Galaxy 2.0 Tdci
Posted: Sun Dec 30, 2018 11:34 am
by m_focus
Im not professional but cyl1 and cyl4 injectors looks bad.
Posted: Mon May 20, 2019 11:55 am
by stojanhu1981
Did you find out that injectors are bad?
Regards,
Stojan
Posted: Tue May 21, 2019 7:40 pm
by denbo
The best way to test these injectors is with a leak off test. buy the kit with bottles and be 100% sure.
Posted: Wed May 22, 2019 10:03 am
by stojanhu1981
can you suggest me what to do?
when i start the engine i have this :
CylBal_1 0.91898772 Cylinder 1 Contribution/Balance
CylBal_2 1.11977880 Cylinder 2 Contribution/Balance
CylBal_3 1.07836316 Cylinder 3 Contribution/Balance
CylBal_4 0.90269004 Cylinder 4 Contribution/Balance
idle is fine, no smoke in idle. Only somethimes the noise when the engine is cold under load : https://drive.google.com/open?id=1qPjIo ... tndZWEDVzX
when the engine is warmed up i have this:
CylBal_1 0.91785848 Cylinder 1 Contribution/Balance - replaced nozzle, OK - tested
CylBal_2 1.22247860 Cylinder 2 Contribution/Balance - replaced nozzle, OK -tested
CylBal_3 1.37040904 Cylinder 3 Contribution/Balance - tested, OK
CylBal_4 0.61683972 Cylinder 4 Contribution/Balance - new
https://drive.google.com/file/d/1Sq8EJ8 ... sp=sharing
when the ingine is hot i have no noise, smoth idle, no excesive smoke.... I've also swapped injectors from Cylinder 4 on Cylinder 3 but value on Cylinder 3 stays over 1.3. Back leak on Cylinder 3 was almost the same as on Cylinder 4 -under 10ml per minute. Also on test bench was a back leak 5.8ml/min.
Regards
