mk6 transit 2.4 di fuel metering testing ?????
madxbri
Vehicle: mk6 transit 120 rwd di
Post by madxbri » Thu Dec 06, 2018 11:35 am
hi i have a 2002 transit mk6 rwd 120 di
can i test the fuel metering valve with forscan to check if fault is the pump etc as all other symptoms does not point to pump fault but limited fuelling comes up
denbo
Vehicle: ford focus 16 zetec
Re: mk6 transit 2.4 di fuel metering testing ?????
Post by denbo » Fri Dec 07, 2018 5:47 pm
Can you explain "limited fuel coming up". I hope you are not undoing the injector pipes. This is very dangerous and can kill you,plus it proves nothing. The moment you open the line the pump stops. Read the fuel pressure from the diag tool ONLY. Check if you have an intank pump. No low pressure = no high pressure.
madxbri
Post by madxbri » Fri Dec 07, 2018 8:36 pm
Fault code limited fueling I am not not touching fuel pipes just needed to know how and where to test fuel pump on software etc if possible thanks as fault comes up as that
denbo
Post by denbo » Sat Dec 08, 2018 9:27 pm
OK, thats good. When was diesel filter last changed?
madxbri
Post by madxbri » Sun Dec 09, 2018 2:16 pm
Has had 2 sins problem just incase maybe thinking dirty injectors causing back pressure maybe the ones in my van are not codded so can't test just not sure if that would cause the problem
