Restraint control module not found *Solved*
Kugamark18
Vehicle: Kuga Titainium 2.0d 2016
Re: Restraint control module not found
Post by Kugamark18 » Wed Dec 12, 2018 9:32 pm
Andyfocus
Re: Restraint control module not found *Solved*
Post by Andyfocus » Wed Dec 12, 2018 11:51 pm
damn thats some serious ouchy lol , only had to replace front bumer ,grill ,top plastic slam panel ,wheel arch liner , rcm module and the lower rad pack holder , headlight still needs a bonnet ( from bent down straighten and filler and sprayed till i can a replacement )and a rear door ( door only slightly dented filled it and lightly sprayed till i can get another ) ,along witha few trim bits , looks like someone had already tried to fix some stuff as the rcm picked up a seatbelt tensioner problem and when i looked it had cmax wrote on it lol .
But glad you got it sorted .
the long and lat sensors will always need redoing when replacing the rcm but as you couldnt see it i didnt get chance to say anything about it , and didnt really know it would effect the steering lock like that ( mine is nornal lock none electric so didnt have that problem ) , was the guy who came out local to you ? could use him to do my pats and reprogram the keys lol .
Kugamark18
Post by Kugamark18 » Thu Dec 13, 2018 9:02 am
He was from the Widnes, Liverpool area
Thanks for your help mate
Mark
