Newbie here with a 2018 Raptor getting ready to try OBDLink MX+ with a Windows tablet.
First simple question- do I unplug the OBDLink after I have made the changes?
Unplug OBDLink MX+ after updates? 2018 Ford Raptor
Re: Unplug OBDLink MX+ after updates? 2018 Ford Raptor
First thing, as you are new to this is contact your bank manager. This is a tool not a toy. Learn how to make a "backup", that way if you make a boo boo you can go back. Then you will need "battery support" because if the voltage drops it will all go pear shaped. Read everything you can and give it a go, someone on here will help you out of a mess, hopefully.
??? Are you sure you replied to the correct post?denbo wrote: ↑Wed Nov 28, 2018 6:37 pmFirst thing, as you are new to this is contact your bank manager. This is a tool not a toy. Learn how to make a "backup", that way if you make a boo boo you can go back. Then you will need "battery support" because if the voltage drops it will all go pear shaped. Read everything you can and give it a go, someone on here will help you out of a mess, hopefully.![]()
2018 Wildtrak 3.2L Auto Supercab 4x4 in Pride Orange
2006 Mondeo MK3
2006 Mondeo MK3
Yes, after saving them. The OBDLink is just an interface between your truck and your tablet. The changes you made are stored in your trucks modules, not in the OBDLink.
Thanks All. Seems to be working.
