Reset electric seats and airbag light 2008 Mondeo
Posted: Mon Nov 12, 2018 2:50 pm
by Stormfugl
I installed new driver and passenger seats in my 2008 Mondeo 2.0TDCI, the seats are electic adjustable with memory. The "new" seats is fram a crashed car, but I tested them in the old car before I installed them in my car.
Problem 1:
Non of the seats reacts when I try to adjust possision, The seat heater work, but nothing else on them.
I am sure they are connected just as the old seats were
I googled that the new seats need to be programmed so I bougt a ODB2 with ELM327 (https://www.ebay.com/itm/Modified-ELM32 ... 2749.l2649
and FORScan Extended lisence
But it wont connect to the DTC
(WARN) [15:38:17.069] Checking COM3...
(OK) [15:38:17.397] Connection to adapter has been established: COM3
(OK) [15:38:17.397] Adapter: ELM327 v1.5
(OK) [15:38:21.195] Connection to vehicle has been established
(OK) [15:38:21.196] Vehicle: Ford Mondeo Duratorq Turbo Diesel Common Rail Injection 2.0L 2011 MY
(OK) [15:38:21.581] Found module: TCM - Transmission Control Module
(ERR) [15:38:21.710] TCM: Unable to read DTC
(OK) [15:38:21.784] Found module: PCM - Powertrain Control Module
(ERR) [15:38:21.832] PCM: Unable to read DTC
(OK) [15:38:21.941] Found module: OBDII - On Board Diagnostic II
(OK) [15:38:22.207] Found module: SASM - Steering Angle Sensor Module
(ERR) [15:38:22.300] SASM: Unable to read DTC
(OK) [15:38:22.305] Found module: ABS - Antilock braking system
(ERR) [15:38:22.357] ABS: Unable to read DTC
(OK) [15:38:22.363] Found module: BCMii - Body Control Module
(ERR) [15:38:22.458] BCMii: Unable to read DTC
Problem 2:
The airbag light also start so ligth, i suppose it is because it cant connect to the seat arbags
I am wery happy if anyone can help me find a solution!
