DSC Malfunction
Brans
Vehicle: Mazda Axela ,2014, 2.0L
DSC Malfunction
Post by Brans » Tue Oct 30, 2018 1:45 am
Good Day,
I have a Mazda 3 2014. I was recently in an minor collision and the DSC light came on. The vehicle infotainment system says it is a DSC malfunction. Repairs were carried out but they forgot to clear the code on the vehicle therefore the light is still on. Can this be done with FORScan?
Thanks in advance for the help.
warpc0il
Vehicle: Mazda RX-8 (all versions)
Re: DSC Malfunction
Post by warpc0il » Fri Dec 28, 2018 12:05 am
AFAIK the DSC system performs a pre-flight check every time the ignition is switched on.
The warning light goes off if the checks are clear or stays on if the check fails.
If your light stays on then that implies that something has not be fixed correctly and the system isn't happy.
Dave
aka The Spin Doctor ™
uǝǝɹɔs ɹnoʎ ʇɹǝʌuı ǝsɐǝld :ɹoɹɹǝ
