Ford Explorer 2013 XLT multiple faults after battery replaced
Posted: Sun Jul 15, 2018 7:15 pm
by wingnutr
Newb here, I have my 2013 Explorer XLT battery died on me recently. I jump started the car to get home and a new battery was installed t replace the old one under warranty. But the first time the car was powered on with the new battery there were multiple faults light up; Check Brake System, Hill Descent Control FAULT, Service Advance Trac, ABS light is also on. Downloaded FORscan hoping to clear the DTC's but to no avail. this is the DTC on the ABS:
Code: U3000 - Control Module
Additional Fault Symptom:
- General Checksum Failure
Status:
- Malfunction Indicator Lamp is On for this DTC
Module: Antilock braking system
Freeze Frame :
-GLOBTIM: 170246165 sec - Global real time
-POWER_MODE: Running - Power Mode Status
-ABS: Inactive - ABS
-AYC: Inactive - AYC
-BTCS: Inactive - BTCS -201D
-HDC: Inactive - HDC
-RSC: Inactive - RSC
-BTC: Inactive - BTC
-VAC_BST_ST: Inactive - Active Vacuum Booster State
-BST_REL_SW: Inactive - Booster Release Switch State
-HYD_PMP_ST: Inactive - Hydraulic Pump State
-VPWR_ABS: 12.30 Volt - Module supply voltage
-VSS: 0.0 km/h - Vehicle Speed.
I tried ABS Module reset but still no go.
I hope someone can help me get enlightened.
Re: Ford Explorer 2013 XLT multiple faults after battery replaced
Posted: Sun Apr 14, 2019 4:37 pm
by aboadi
Kindly charge the new battery fully. I experienced a similar problem and I charged the battery fully and all the problems indicated vanished. 2013 Ford explorer xlt 4x4
Posted: Sun Apr 14, 2019 6:46 pm
by gg1234635
Dont forget you need to tell the system it has a new battery installed. There is a procedure in forscan for that
Posted: Mon Apr 15, 2019 11:47 pm
by lenko
You enter the new battery code at BCM 726-04-01 XXxx xxxx xxxx LARGE Xs. See here: https://www.icloud.com/numbers/0AtiYU-y ... _Explorers.
After you enter your code hit write and follow the directions.
