mazda 3 BK 1.6 DI 80 kw P0193 error
Daemon444
Vehicle: mazda 3 1.6D 109CP 2006
Post by Daemon444 » Sat Jun 16, 2018 2:47 pm
Yesterday my car engine died at the stop and will not start.
Thx to the amazing forscan software I read the error codes and turns out to be:
===PCM DTC P0193-21===
Code: P0193 - FRP Sensor High Input
Additional Fault Symptom:
- Signal is Above Maximum Threshold
Status:
This DTC may be caused by :
Pressure regulating valves or controls
FRP sensor/wiring
Fuel injector faults
Faulty or damaged PCM.
===END PCM DTC P0193-21===
The car started with starter helper spray and is still starting but I think there must be something wrong.
The engine runs not so round.
Here is live data.
What you guys think should I replace the FRP sensor is it faulty?
at idle warm
live frp.PNG (42.15 KiB) Viewed 170 times
