ABS and Traction Control Fault after Replacing Battery
arslan.hamid
Vehicle: Ford Explorer XLT 2012, 3.5L
Post by arslan.hamid » Sat May 12, 2018 1:23 pm
Hi people,
I replaced my positive battery terminal connector (circuit breaker assembly) on Explorer 2012 XLT after it got corroded. After starting the car, I got ABS related fault lights such as parking brake, ABS and traction control. Using forscan, I got the code U3000-41AB checksum failure on ABS.
Tried to clear this using forscan but the error persists. The brakes work fine, ABS also engages fine.
Please guys help me out on how to fix this?
arslan.hamid
Re: ABS and Traction Control Fault after Replacing Battery
Post by arslan.hamid » Sat May 12, 2018 3:00 pm
Bump
MJRVR
Vehicle: ford fiesta 1.6 tdci 2006
Post by MJRVR » Sat May 12, 2018 5:19 pm
Double check your connections that you touched.
arslan.hamid
Post by arslan.hamid » Mon May 14, 2018 6:09 pm
Update: Issue got solved after I performed a module reset and calibration on Forscan.
Thanks to the developers of Forscan!
TrhodesEdge
Vehicle: 2013 Ford Edge 3.5L
Post by TrhodesEdge » Wed Oct 17, 2018 11:30 am
What exactly did you do? I am having the same issue after replacing battery. Thanks!
denbo
Vehicle: ford focus 16 zetec
Post by denbo » Thu Oct 18, 2018 6:58 pm
This usually happens when the battery is disconnected before all the modules have gone to sleep. A lot of patience and learning is required when working on modern vehicles.Same thing when re connecting. Every day,s a school day.
