DPF pressure readings Transit 2.2 Duratorq 2012
colinlees
Vehicle: Transit 2.2 diesel 2012
Post by colinlees » Sat Mar 24, 2018 6:55 am
Hi, have searched for previous posts on this but can't find any. Having recurring issues with the EML light coming up for a few months. Garage have done at least 2 regens, changed sensor and DPF (1 month ago) Light still coming on.
Looking at readings on Forscan and it shows 2 DPF pressure sensors, but when running I only get a reading from sensor 1, sensor 2 staying at 0. Should I be getting a reading for this sensor? Also fuel consumption has gone up, reset MPG at DPF change, gone from 30.7 down to 28.5.
Any thoughts/suggestions welcome as the light is coming on, and going into limp mode after only a mile or so after clearing DTC's
MJRVR
Vehicle: ford fiesta 1.6 tdci 2006
Re: DPF pressure readings Transit 2.2 Duratorq 2012
Post by MJRVR » Thu Mar 29, 2018 11:33 am
What codes are you deleting?
Lots of reasons why a DPf won't regenerate.
jonny
Vehicle: Ford Ka - insigma 1.5 flex - year 2013 -
Post by jonny » Tue Apr 03, 2018 1:53 am
Hí to all.
I have the same problem.
error code is P244D
colinlees
Post by colinlees » Tue Apr 03, 2018 7:54 pm
Haven't noted the exact codes down but 244 (possibly 243) a and c from memory. DPF soot loading too high, differential pressure too high. have used the dashboard to monitor some readings while engine running. Coming up with Exhaust gas temp 1000c even when engine cold and not running - seems stuck on that reading. seen this reported elesewhere, is it a default error reading? Also EGR valve position reading 100% while command reads 0%, returning a -100% error reading - does this indicate a stuck EGR valve?
When I get a chance tomorrow will reread codes and note down to update on here.
denbo
Vehicle: ford focus 16 zetec
Post by denbo » Wed Apr 04, 2018 6:05 pm
Why not start by changing the garage you use! Get it to a garage that knows the system, has the correct test gear instead of changing parts at a guess. All at your expense. Sorry i don,t mean to be rude, but i see this sort of thing every day.
Damien89
Vehicle: Ford Transit 2007, 2014
Post by Damien89 » Sun Jul 29, 2018 5:35 pm
How did you end up? Did you fix the problem?
