U3000:4A Control Module:Incorrect Component Installed Fusion
retiredguy
Vehicle: Fusion, SE 2015
Post by retiredguy » Wed Jan 17, 2018 8:31 am
After replacing the front seats from a 2018 to my 2015 I get a U3000:4A, Forscan is saying this is a RCM -Incorrect Component Installed. This DTC will set if the RCM detects the incorrect vehicle ID or model year ID from the Occupant Classification System Module (OCSM), PCM or ABS module. I tried resetting DTC and the module in Forscan but it has no affect. How do you reset OCSM? Is is possible to do it in Forscan.
