New Service Functions Ford Ranger Mazda BT50 3.0 WE/CD
avkdm
Vehicle: 2008 Mazda BT-50 SDX
Post by avkdm » Tue Dec 16, 2014 11:34 pm
Hi FORScan team,
Do you plan to implement many more service functions for Ford Ranger/ Mazda BT50 WE/CD 3litre?
I note you have implemented many service functions for later model 2011 Ford Ranger/Mazda B Series 2.2/3.2
Many thanks in advance.
Re: New Service Functions Ford Ranger Mazda BT50 3.0 WE/CD
Post by FORScan » Wed Dec 17, 2014 8:00 am
In general case, Ranger/Mazda of 2011 model year has the PCM of latest generation that has much more functions that the previous one, installed on Mazda/Ranger of 2007-2008 model year. What are the functions you would like to see in FORScan?
avkdm
Post by avkdm » Wed Dec 17, 2014 1:03 pm
FORScan wrote:In general case, Ranger/Mazda of 2011 model year has the PCM of latest generation that has much more functions that the previous one, installed on Mazda/Ranger of 2007-2008 model year. What are the functions you would like to see in FORScan?
Do you have a list of what is available?
I was thinking
Reset all Adaptions
If available individually items listed below
Reset MAF learned values
Not sure if these below apply to Ranger/Mazda BT50 2007/2008
Reset EGR Valve Adaptions
Reset 02 Sensor learned values
Reset Air Intake Throttle Valve Learned Values
Reset Knock Sensor learned Values
Only of course if these are available as I am not familiar with M-MDS functionality.
Post by FORScan » Tue Dec 23, 2014 5:44 pm
Unfortunately, this model has quite little of service functions. In addition to programming injectors (implemented in FORScan), we know only 2 function: Reset All Adaptations (PCM reset, used when some components are replaced, details have to be found in workshop manual) and MAF reset.
avkdm
Post by avkdm » Tue Dec 23, 2014 10:28 pm
FORScan wrote:Unfortunately, this model has quite little of service functions. In addition to programming injectors (implemented in FORScan), we know only 2 function: Reset All Adaptations (PCM reset, used when some components are replaced, details have to be found in workshop manual) and MAF reset.
If these other two (Reset All Adaptions and MAF Reset) can be implemented at next or future update, that would be great.
Thanks FORScan Team!
Post by FORScan » Wed Dec 24, 2014 1:35 pm
OK, we have added these features to the queue.
