BA Falcon replace BEM
hfinlay10
Vehicle: Ford Falcon BA
Post by hfinlay10 » Tue Jan 09, 2018 11:53 am
Hi, I need to replace the BEM on my BA Falcon - random door lock cycling, power window fails, and engine immobilising, also parasitic battery drain that only stops when 5A BEM fuse is pulled.
I have a replacement BEM (same colour [blue], from eBay), but just want to check that all that is needed to pair BEM and PCM is to redo the keys using PATS, or is there more to it?
TIA
Sam1112
Vehicle: [AUS] Ford Fairmont Ghia [BA Mk2] [4L Straight 6]
Re: BA Falcon replace BEM
Post by Sam1112 » Wed Jan 10, 2018 8:47 am
No, Thats all to it, just make sure that you have two keys, as the PATS Programming cannot be completed without a minimum of two keys, you might also have to run the 'ACM' Calibration to match the ICC to the car again, thats if it just keeps reading the word 'code' on the screen.
hfinlay10
Post by hfinlay10 » Wed Jan 10, 2018 9:49 am
OK, thanks.
