help me understand P2458-21
Gabi4175
Vehicle: ford focus 2 1.6 tdci 109 hp 2009
Post by Gabi4175 » Fri Dec 29, 2017 8:20 pm
ok so every time i delete P2458-21 i get it back after long trips over 60km. the dpf pressure it's 0.3 kpa idle and max 5kpa at 3000rpm. So does this error really means because i doubt that the filter is full but the pressures inside are this low
Hallex
Vehicle: Mazda 3BL 2009 Y6
Re: help me understand P2458-21
Post by Hallex » Sat Feb 17, 2018 5:37 pm
I've replace my DPF by a new one on my Mazda 3 1.6 MZ-CD and i have the same delfaut code. I've check the DPF additive it's OK, check all the sensor and connector : OK
But when i delete the delfaut, it comes some km after.. DPF regen every 150km it's so borring, my car consume a lot.. Can't find a solution !
Have you find a way ?
Thank's for a reply ! :( ;)
Mazda 3 BL 1.6 MZ-CD - Celestial Blue
MJRVR
Vehicle: ford fiesta 1.6 tdci 2006
Post by MJRVR » Sat Feb 17, 2018 7:36 pm
Hallex wrote:Hello,
Did you tell the ECU it has a new DPF?
Vehicle: Ford XR6 Turbo BA MK II 6 Speed Manual
Post by f-wolf » Sat Feb 17, 2018 8:30 pm
Post by f-wolf » Sun Feb 18, 2018 12:11 am
The Truth About Modern Diesel Particulate Filter Problems (DPF Problems)
https://autoexpert.com.au/posts/the-tru ... f-problems
Hallex
Post by Hallex » Mon Feb 19, 2018 10:40 am
MJRVR wrote:
Hallex wrote:Hello,
Hello MJRVR !
Yes, when i replace the DPF i've proced to a DPF Reset in Forscan, and with IDS Mazda one week later because the delfaut code was were again ! But no change, i've check all sensor, hose, clean DPF sensor (on the DPF) but always the code. My DPF say 0.1-0.3kPA at idle and max 3kPa when i drive (acceleration) is it good ?
Check the additiv DPF is ok too. Just refill at 65 000km
The new DPF have been replace at 97 045km, now i'm at 99 125km.
loscalpello
Vehicle: Focus 1.6 tdci , engine HHDA/90hp,2009
Post by loscalpello » Fri Mar 02, 2018 10:40 am
Hallex wrote:
MJRVR wrote:
Hallex wrote:Hello,
Hello MJRVR !
When I detect a P2458 or similar on Fcus/C-Max 1.6 , I replace :
1) The olf DPf , whit a regenerated DPF ( the same model )If necessary .
2) The dpf sensor of pressure , or at least I try another who works well from another car .
3) Clean ( or replace if necessary ) the EGR valve ALL THE TIME .
4) Clen the intake manifold , it is possible and all kind of links to it .
5) Clean the intercooler and its pipes .
6) Reset the DPF and EGR parameters whit FORSCan
In this mode the car works well.
Regards from Italy
Hallex
Post by Hallex » Wed Mar 14, 2018 10:09 am
Hello loscalpello !
Thank's for your help !
1) For me the DPF have been replaced with a new one now there is 2 000km
2) The DPF pressure looks good like 0.1-0.2 kPa in idle, and 3kPa max at 3000tr/s !
3) I've clean the EGR yesterday but i don't know if the values looks good, can you give me good values ?
4) I don't have yet clean my intake manifold but maybe near
5) All the pipes, intercooler, ... are clean !
6) I've reset DPF and EGR with Forscan yesterday
But i'm thinking than it's the EGR the problem ! But for this i don't know who are the good values for a working EGR. I'll post a pic about my Forscan Data !
The P2458 come after my DPF try to regen.. :(
PS : i've made a topic for me http://forscan.org/forum/viewtopic.php?f=6&t=6002 there is my Forscan statistic :?
denbo
Vehicle: ford focus 16 zetec
Post by denbo » Mon Mar 19, 2018 10:28 am
Look at egr in live data with engine running, take note of value. Rev engine momentarily, value should go to 0.00 for a second.This shows egr closed. If not fit new egr, cleaning seldom works.
