2012 focus traction control
catfish
Vehicle: 2012 ford focus 2.0l
Post by catfish » Fri Dec 12, 2014 1:40 pm
Are there any plans to include an option to disable traction control? I have an S model so I don't have the buttons and display that other models have to allow me to do this. Since other FF models allow this I don't think it should be a problem.
Re: 2012 focus traction control
Post by FORScan » Sat Dec 13, 2014 10:00 am
You are probably right, but at this moment there is no such option available, and we also have no information on how to do it using a scantool.
catfish
Post by catfish » Sat Dec 13, 2014 12:41 pm
if you do find a method, there are lots of other folks looking for a something to do this and would be interested. Could you monitor the can bus when a model with the controls deactivates it and repeat the same commands?
Post by FORScan » Tue Dec 16, 2014 8:18 am
FORScan uses special diagnostic protocols. It doesn't try to use or analyse internal communication protocols between modules. So if such a function provided by a module, it can be done (principially). Otherwise, it can not be done.
Abyway, we will keep this request in mind.
