Reset/ReLearn RCM - Ford Focus MK3 - procedure interuption
rfr78
Vehicle: Focus 2013 Estate 1.6 125Hp
Post by rfr78 » Sat Dec 09, 2017 12:16 am
Hi!
I have added recently APIM and have Code: U0452 - Invalid Data Received From Restraints Control Module
So I tried to reset or initialize/Relearn RCM but after procedure is started... and right away interupted.
Anyone had same problem with resetting RCM?
regards
rfr78
rfr78
Re: Reset/ReLearn RCM - Ford Focus MK3 - procedure interupti
Post by FORScan » Sat Dec 09, 2017 1:03 am
Please contact support and provide FORScan logs for analysis.
Post by FORScan » Wed Jun 13, 2018 4:45 am
In many cases the DTC U0452 after APIM installation means that the Emergency Call parameter must be enabled in RCM. If this parameter is missing in FORScan for your car, please contact our support.
