Strange issue
mgs41987
Vehicle: focus 1.8tdci 2009
Strange issue
Post by mgs41987 » Fri Jul 28, 2017 8:19 am
Hi Guys new issue has arisen. the other day the car wouldn't start no MIL nothing just turned over and turned over, got trusty forscan out and it said it was the fuel rail pressure sensor implausible signal. so naturally i buy a genuine new sensor, replaced it and as soon as i put the ignition on dashboard came up saying ENGINE MALFUNCTION, i thought it must be to do with the new sensor but none the less the engine started first time but in limp mode with engine malfunction on the dash and traction control light.
Thinking it might clear itself i turned engine off then ignition on and the message came up again and same scenario, i got forscan out and it came up with a message of
===PCM DTC P0193-61===
Code: P0193 - FRP Sensor High Input
Additional Fault Symptom:
- Signal is Above Maximum Threshold
Status:
This DTC may be caused by :
Pressure regulating valves or controls
FRP sensor/wiring
Fuel injector faults
Faulty or damaged PCM.
===END PCM DTC P0193-61===
===OBDII DTC None===
Successful DTC reading, no error codes found
Module: On Board Diagnostic II
===END OBDII DTC None===
===ABS DTC U2023-E0===
Code: U2023 - Vehicle Communication Network Fault
Status:
- Malfunction Indicator Lamp is On for this DTC
Module: Antilock braking system
Note:
DTCs that start with 'U' are faults which occur during module-to-module communication.
Modules should never be replaced based only on a 'U' code. These codes do not always indicate a problem, and can be caused by normal diagnostic functions, carried out on the vehicle.
For further diagnostic information refer to the appropriate section of eTIS.
I sent the sensor back thinking it could be faulty, put the old back in, the car wouldnt start but i got no engine malfunction or anything, new senor arrived so same scenario, it does this before you turn the engine on and it comes up in the self test, so it must be another fuse/relay/solenoid causing the issue! any body got any ideas ?
denbo
Vehicle: ford focus 16 zetec
Re: Strange issue
Post by denbo » Wed Aug 02, 2017 7:22 pm
What vehicle? what engine, what fuel? give us something to work with.
mgs41987
Re: Strange issue update!!
Post by mgs41987 » Sat Aug 05, 2017 7:49 am
i didnt write the car etc as its next to me username but its a ford focus 2009 1.8 tdci
i was doing some voltage tests after i got the information for what pin gives what voltage at what time, with ignition on pin 1 is ground (which is correct) pin 2 is supposed to be .3v but it gives 5v and pin 3 gives 5 which is correct. as the loom looked fine i sent the ECU off for testing, the wiring diagram looks as though the FRP is only connected to the ECU, as these are known to be faulty they cloned my ecu to another as they could test it and the fault is still there.
does anybody else know what it could potentially be. i am taking the looms off today and stripping them down in case they have chaffed and joined 2 circuits together
denbo
Re: Strange issue
Post by denbo » Wed Aug 09, 2017 7:37 pm
Hold on here,,,,,What is the fuel pressure? I,m thinking it should be around 250 bar. More than that and it will not fire. But it will build up a high pressure if the injectors don,t open. So, are the injectors opening on initial crank? If not the pressure will increase to a dangerous level and the pcm will shut down. Do you have cam and crank sync. Throw a scope on it and see whats happening! Do you have any other fault codes in any modules. Those frp sensor v readings are wrong, as you know, earth, 0.5v, 5v. is what you need to see. My money is on the pcm. Who tested it.
mgs41987
Re: Strange issue
Post by mgs41987 » Thu Aug 10, 2017 12:55 pm
The PCM (ECU) was sent to the ecu doctor Plymouth, they said they couldn't test it but they cloned my ecu's security data over. so i have had a replacement ecu but the issue did not go away. the car runs but stuck in limp mode with new sensor and old sensor it wont start.
i will get some reading over the weekend
mgs41987
Re: Strange issue
Post by mgs41987 » Thu Aug 17, 2017 1:08 pm
All sorted ended up being electrical
Daemon444
Vehicle: mazda 3 1.6D 109CP 2006
Re: Strange issue
Post by Daemon444 » Sat Jun 16, 2018 10:54 am
mgs41987 wrote:All sorted ended up being electrical
What was the actual electrical problem ?
So the connection bettwen the sensor and PCM some wire was broken or.. ?
I have exacly the same problem on a Mazda 3 1.6 DI.
Same error code.
Thx.
Daemon444
Re: Strange issue
Post by Daemon444 » Sat Jun 16, 2018 2:40 pm
I think is the sensor on mine as is to much preasure ...
What you guys think ?
FRP at idle
Live data
live frp.PNG (42.15 KiB) Viewed 906 times
Donny
Re: Strange issue
Post by Donny » Sat Jun 16, 2018 9:28 pm
Deamon444, 32780 KPa = 327.8 Bar, which looks right for Idle Pressure. I don't have the same car as you but my Idle Pressure is around 300 Bar.
I haven't tried this in the laptop version of FORScan, but in the Mobile Phone version you can change the units to show the values in Bar by clicking onto it.
