Backup camera calib error B115E:08-48
mandrews
Vehicle: f-150,gas5.0,2017
Re: Backup camera calib error B115E:08-48
Post by mandrews » Wed Jul 04, 2018 9:22 pm
I'm getting ready to retrofit a cam in my 17 f150. have all the ford parts now but need the wiring diagram for the plugs from fender well to tailgate harness so i can add the wires to plug correctly anyone have a link or info?
Vehicle: *** Ford ***
Post by f-wolf » Thu Jul 05, 2018 4:15 am
DBooth
Vehicle: 2015 f150 3.5 n/a
Post by DBooth » Fri Jun 14, 2019 11:03 pm
Anybody have this issue? Did the camera install thing everything works image is right side up, zoom works, dynamic lines are there and turn with the steering wheel BUT as soon as I move in reverse the lines go all the way left and stay there until I stop moving then when ove back to center. The camera is a OEM replacement from rock auto and is made by dorman. When I do the calibration I get the same error code as everybody else. Any ideas?
BBradley52
Vehicle: 2013 Ford Fusion Hybrid
Post by BBradley52 » Fri Jun 14, 2019 11:33 pm
I just installed the same camera in my 2013 Fusion. I get the same results with the guidelines. I haven't tried to calibrate yet. (Waiting on interface module from Amazon but have installed Forscan software). I suspect it is because we didn't install an OEM camera. Hope not because we can't return to Rock Auto. I sent Dorman Tech Support an email, but no response. Not much hope. I think we're screwed.
BBradley52
Post by BBradley52 » Sun Jun 16, 2019 4:25 pm
Got ELM adapter and installed with software successfully. Ran calibration of Dorman (aftermarket camera). Calibration SAID it was run successfully. Interesting because most say that it faults at 8% of calibration run. Mine ran to around 20-30% then asked me to turn off and back on Ignition. After doing this, it ran to completion of 100% and said the calibration was successful. The only problem is the guidelines act just as before. Once you move in the reverse direction the white guidelines go to hard left and stay there regardless of wheel position until you come to straight position near stop. Again, this must mean that you MUST use OEM camera and not aftermarket regardless of the price.
denbo
Vehicle: ford focus 16 zetec
Post by denbo » Mon Aug 12, 2019 6:18 pm
I think dorman in the US are same as euro car parts in uk, cheap useless rubbish.
Levowen
Vehicle: Ford transit, 3.5L, 2017
Post by Levowen » Tue Oct 22, 2019 11:38 am
I had my rear camera replaced with a part from ford after an accident. But now rear guidelines are not showing. Dealer doesn’t know how to fix it. After reading this forum I bought a lead to use with FORScan. But my vehicle doesn’t have the recalibrate camera option in FORScan.
Anyone have suggestions on what to reset? The the camera is throwing a DTC that says it requires calibration.
