Clear Crash data using ELM327
keefSure
Vehicle: Ford S-Max 2.0 TDCI/143ps 2007
Post by keefSure » Wed Apr 05, 2017 10:45 am
Tried clearing Crash data using the ELM327, it clears but then ignition off and on again it comes back, see below:
Ford S-MAX 2007 2.0L TDCi Duratorq
Code: U1A37 - Crash Status Telegram
Status:
- Malfunction Indicator Lamp is On for this DTC
The RCM crash data memory is full, due to a crash event that has deployed the air bags
RCM U1A37:00-8A
Anybody know if this can be cleared? only both pretenioners were gone and now replaced just leaving crash data
keefSure
Re: Clear Crash data using ELM327
Post by keefSure » Wed Apr 05, 2017 11:33 am
Appreciate any help on this
setsail4mexico
Vehicle: 2015 F150 5.0L
Post by setsail4mexico » Thu Apr 06, 2017 1:22 am
In my past experience, I've always had to replace the module. I've been told that once crash data is written it cannot be cleared as it is written to ROM (read only memory) that is reserved for crash data. Not sure if that is correct but all attempts to clear it or change coding has failed for me and had to simply replace the module. If you figure it out, be sure to post. Good luck!
keefSure
Post by keefSure » Thu Apr 06, 2017 11:09 am
Seems the only way you can clear it is on a bench through the EPROM, spoke to a chap that does this, so the process is below
1) disconnect battery
2) remove the airbag ECU
3) technician clears the data using eprom by copying the data from a good module
4) install airbag ECU back into vechicle
5) connect battery
I thought maybe FORScan has a way of doing this, maybe not on this particular vehicle?
Cheers
bizkitt
Vehicle: Mondeo MK4, 2.0 TDCI, 138hp, 2007
Post by bizkitt » Sat Apr 08, 2017 1:13 pm
Hi, keefShure EEPROM is usually done on a bench as its a direct HW erase and flash procedure and i highly doubt that it can be done via OBD thats why its a "bench" job :D
Cheers
william
Post by william » Sat Apr 08, 2017 3:46 pm
Here's what ford say about the dtc.
DTC U1A37 00: Crash status telegram *RCM crash data. *Clear the data memory using the Ford diagnostic equipment. REPEAT the self test, CLEAR the DTCs.
08 mk4 mondeo 2.0 140 bhp
keefSure
Post by keefSure » Wed May 03, 2017 11:53 am
Thanks everyone, I've got this cleared now using the bench method, no longer showing crash data
Post by FORScan » Wed May 03, 2017 3:19 pm
Crash event has to be reset using service function "Crash Flag Reset" in FORScan. The function is available only for European models. For Mondeo 4, Smax and Galaxy crash has to be reset in RCM, then (if necessary) in BCM module. DTCs must be cleared after crash reset. Using service tool, crash can be reset up to 5 times, then RCM module has to be replaced or cleared directly in EEPROM using special equipment.
Paxtonix
Vehicle: Ford mondeo mk 4
Post by Paxtonix » Thu Jul 06, 2017 9:46 am
HI guys.
having problem here with my mondeo 2008 MY07.25 .
had crash , airbag light is on
Due to reset flag in RCM module after 1 % progres the program returns with a msg: Operation failed please contact the program author. in the end Unable to delete RCM memory. :(
any clues why ?
car details
Primary Features
Build Date: 05.02.2008
Vehicle Line: Mondeo 2007-2014
Body Style: 4 Door Estate
Version: Series 60
Engine: 2.0L Duratorq-TDCi (143PS) - DW
Transmission: 6 Speed Manual Transaxle - MMT6
Drive: LHD FWD
Emission: Stage IV + DPF Emissions
Air Conditioning: Dual Zone Auto Temp Control A/C
Territory: (+)"D"
Paint: Deep Navy
Interior Fabric: New York / Ebony
....kekko91...
Vehicle: Ford fiesta mk7 1.4 TDCI
Post by ....kekko91... » Sun Nov 19, 2017 12:56 pm
FORScan wrote:Crash event has to be reset using service function "Crash Flag Reset" in FORScan. The function is available only for European models. For Mondeo 4, Smax and Galaxy crash has to be reset in RCM, then (if necessary) in BCM module. DTCs must be cleared after crash reset. Using service tool, crash can be reset up to 5 times, then RCM module has to be replaced or cleared directly in EEPROM using special equipment.
Is it possible to do the same thing on 2009 ford fiesta EU model? I have the airbag light on the cluster and B1193 dtc
