bench setup with no ECU
wystewart
Vehicle: Mustang GT, 5L, 2014
Post by wystewart » Tue Feb 28, 2017 2:13 am
Is it possible to use Forscan with only an APIM/ACM on the bench outside the car without any other modules (ie. no ECU/PCM). when I try to connect, it says unable to connect to the vehicle.
fred08155
Re: bench setup with no ECU
Post by fred08155 » Tue Feb 28, 2017 7:33 am
Newest version will not work.
Old v1 version might work. You can download version 1.3.9 at the bottom of the download page.
Version 1 scans the busses for every single module (takes a lot longer).
Version 2 will not work if it is unable to identify the vehicle so i guess it won´t work without PCM connected.
Version 1.3.9 is quite old and has less functionality so it might be no help.
wystewart
Post by wystewart » Fri Mar 03, 2017 1:43 am
thanks. but v1.3.9 doesn't seem to find anything. In any case I would need a more recent version that can edit the as-built.
