Changing default Speedo to MPH from KMH
ericleem
Vehicle: F150, 3.5, 2015
Re: Changing default Speedo to MPH from KMH
Post by ericleem » Fri Nov 30, 2018 9:29 pm
Doesnt seem to have change the default on the digital speedo. It still defaults to KMH when you crank the truck.
lenko
Post by lenko » Sat Dec 01, 2018 9:09 pm
Obviously the reset doesn't work for the Kph change. It's the same on my 2015 Lincoln Mkc. I added the digital speedo but it only reads in Kph whether I set it Kph or Mph. It changes the designation to Mph but shows kilometers in speed. There has to be some other change to be made by Forscan - which we haven't determined where.
moretools
Vehicle: F150, Ecoboost 3.5l, 2015
Post by moretools » Tue Dec 04, 2018 6:00 pm
lenko, you wrote "After you make the change and hit write. Once that's finished go to the top and click on the relearn configuration and programming ". After I make the change and hit write, Forscan generates a pop-up directing me to cycle the ignition. Did you do the relearn before cycling the ignition?
lenko
Post by lenko » Wed Dec 19, 2018 8:14 pm
Cycle the ignition and then do the relearn.
bradenkeith
Vehicle: F150 v8 2015
Post by bradenkeith » Thu Feb 21, 2019 3:46 pm
Any update as to if relearning fixed the problem once and for all?
ericleem
Post by ericleem » Thu Feb 21, 2019 3:59 pm
No it didn’t work for me.
Logan941
Vehicle: F150, 5.0 v8, 2015
Post by Logan941 » Fri Feb 22, 2019 2:15 am
I just tried it tonight on my Canada 2015 f150 and didn't work either
bradenkeith
Post by bradenkeith » Sat Feb 23, 2019 3:11 pm
Bummer. Thanks for the follow up.
mikeimus41
Vehicle: 2015 f150 3.5 ecoboost xlt supercrew
Post by mikeimus41 » Sun Feb 24, 2019 1:42 am
Anyone have any more information, trying to get this changed on my 2015 as well. Any help would be greatly appreciated.
Cmadd78
Vehicle: F-150 Lariat, 5.0 V8, 2015
Post by Cmadd78 » Tue Mar 19, 2019 9:11 pm
I’m scratching my head as well. 2015 F150 from Canada....would love to find a solution to get the digital speedo to default to mph. From what I have read and researched so far, it’s looking like the eeprom for the instrument cluster needs to be reprogrammed and this apparently cannot be done from FORScan.
