Mustang S197 2005-2009 programmable Codes
- Vehicle: 2014 Ford F250 6.7L Powerstroke
Re: Mustang S197 2005-2009 programmable Codes
I too tried to find code line to eliminate hyperflashing but couldn't find it. Nor could I find spreadsheets from forums with many of the common codes for S197s. Seems there's not much want or support for our cars in the forscan realm.
I did try all the similar years Ford vehicles to see if they shared similar coding for hyperflashing but none seemed to change the response in testing.
Also, when I download my as built codes from the etis site, the number of lines in the GEM module file does not match the actual number of lines in the module when I plug in with forscan. Anyone else experience that?
Hi Karsten. This was the post I've been looking for for five years! Thanks so much! I have an '08 mustang V6 ex rental, and I hated the DRL's. One big problem with them is it only activates the headlights. and the dash lights are always on. I've driven home from work at midnight many times with no taillights. This worked real slick, thanks.! Now my new question: is there a list somewhere of the BIN values, what each bit does? Figuring the HEX-BIN conversion works great, just need to know which values do what, to see if there's any other changes I want to make. Thanks again!
I have a 2009 Bullitt - so without the fog lights.
I would have liked to have programmed the daytime running lights. I read it here, got an adapter with switch, activated an extended license.
Then I got the "asbuildexplorer".
As I understood it, one enters the original data blocks into the "asbuildexplorer" in the tab "Check sum calc".
For me these were for the 726-01-01: 2028 0020 039A
So I enter the 2028 at Hex to Bin and it comes out "001000000000101000".
The daytime running light is in the first data block, the first 0 should become a 1, then the daytime running light should work.
If I enter this into the line Bin to Hex, i.e. "1010000000101000", I get "A028" as HEX value.
Is that correct so far?
So I enter "A028" in Forscan and click on "write".
Then it writes twice, 100% once and 51% the second time and I get the error message "Writing blocks failed - incompatible configuration".
Other configurations like programming TMPS and doing away the ringing have worked fine.
Now the questions: Did I do something wrong, is my car incompatible or does the bullitt have another parameter because the foggers are missing?
I would be happy about pertinent hints!
Have a nice Sunday!
Thomas
Have a nice Sunday!
Thomas
- LaForge
- Vehicle: Ford Focus 2011 - Frostwhite LaForge Edition
- Contact:
Hi there,
its been a long time, but sometimes I come back to read the Threads.
No, the Bullit is a mustang normal as every one from 07 to 09.
05 and 06 have a bit different electrics)
So change the first row from 0000 to 8000 and drl is on.
Chack also with a IPC selftest if the DRL led is in the middle left from the turn left arrow.
If its there, you can activate it in the 720-01-01 row as mentined in my grafic above.
Thats all.
The GT has 0004 and the 4 is for foglights on. You have 0000 for a bullit with no fogs.
Change the 726-01-01 from 0000 to 8000 and you are done as said above.
Greets
Karsten
Thats all.
Greets
Karsten
riding da White Beast
ECU Programming Service on Ford Vehicles after 2006
Hyper flash on the 2012-14 models requires more than a resistor. The BCM send a high impedance clock signal that is quenched when the inner light is energised. To overcome outage fail and hyper flash, a transistor (2N2222) and 10k resistor is required to emulate the light cluster.
The collector connects to ground, the resistor to the base and inner lamp signal, the emitter connects to the outage signal.
If you need more help let me know
- Vehicle: 2015 Lincoln MKC, 2006 Mustang GT, Saleen 530 HP
You likely have to install the same version Sync for EU and get the map disk or card for EU. You should determine which Sync you have and post it so you can get advice where to find it and if it is upgrade able.6t07t wrote: ↑Sun Feb 10, 2019 4:31 pmHello,
I'm new here![]()
Please help me with these problems:
- how to change radio frequency with 0.1 step (EU standard) on the 2008-09 factory satelite navi system??
- how to change US to EU road maps on the 2008-09 factory satelite navi system??
- how to disable bulb out hyperflashing with parking/turn lights LED bulbs?
please let me know,
thanks,
Peter
My question more pertains to a way to programmatically shut off the lamp outage in the BCM using Forscan. The resistor I wired in parallel to the bulb works just fine to fool the car into thinking the bulb is incandescent in the meantime.Shabbee wrote: ↑Sun Jun 23, 2019 9:46 amHyper flash on the 2012-14 models requires more than a resistor. The BCM send a high impedance clock signal that is quenched when the inner light is energised. To overcome outage fail and hyper flash, a transistor (2N2222) and 10k resistor is required to emulate the light cluster.
- ponyXpress
- Vehicle: Explorer Sport Trac, 4.6 V8, crew cab, 2007
Hello everyone - I have a 2008 Mustang GT Premium and I would like to change a few things. I have ForScan and I've done this already on my Ford Ranger and a friends F-150, but I've never tried on my Mustang.
Can you please share the full list of mods that people can make using ForScan for the 08 Mustang?
Specifically I'm interested in the following:
Daytime Running Lights On
Bambi mode for fog lights On
Many thanks!
Many thanks!
Hello
I have a GT 2005 from Canada, I just have disabled day running light, the code was:
GEM 726-01-01 8004 > ON
GEM 726-01-01 0004 > OFF
What is bambi mode for light fog ?
- ponyXpress
Bambi mode means that when you turn on your headlight high beams, the fog lights remain on. Factory turns this off by default, means when you go to high beams, the fog lights turn off.
BTW, thank you for the day time running lights codes. Why did you turn yours back off?
