Page 2 of 3
Re: Ford S-Max 2.0 tdci - P003A:17-2F - correct VANE POS values
Posted: Fri Feb 08, 2019 4:54 pm
by correira
I'm dealing with the same DTC P003A:00:2F.
I came form a much worse situation, P2263 from time to time and constant P0299. After some investigation done it appears the turbo actuator solenoid was not working properly, on ebay they called it a turbocharger pressure converter
https://www.ebay.co.uk/itm/1X-PIERBURG- ... rk:17:pf:0
So I've replaced the solenoid and no longer see P2263 and P0299, so I hope that is fixed.
Now from time to time a got a P003A, no impact on car performance as far as I could see, and no LIMP mode.
Since car now have more then 150.000 km might be an intermittent sticky vane issue, I'll try to reach by hand to see if it's moving without any restrictions, but in the meantime I took same graphs on forscan, and I believe that vanes should open more when I accelerate, maybe because I did this on the parking, instead driving it...
Posted: Thu Apr 04, 2019 7:05 am
by daufmen
Hello There
Some one have make solution to fix the problem P003A
For me it's appear after disassembling turbo repair so now I don't know if I can use the car, and the problem even persists that I changed another position detector
If reset the value it's the solution with witch soft can I do... Because here we haven't forscan
Thanks please
Posted: Thu Apr 04, 2019 7:40 pm
by denbo
The problem seems to be sticking vanes. If you disconnect sensor and move lever back and fro with hand, it should be free with no restriction. Any restriction must be addressed to make it free moving. In most cases a strip down and clean is required. However, i have seen some video,s using oven cleaner foam.
Posted: Sun Apr 07, 2019 5:25 pm
by daufmen
finally it was a very important thing about to the control valve adjustment of the variable geometry of the turbocharger
P003A -17
this code means that there is an overshoot at the maximum limit of the opening during suction that must not be greater than 100% on the position sensor reader of the turbocharger control valve, engine in idling without acceleration, and that rule with a stop shaped rod threaded on the turbocharger itself, it blocks the arm of the variable geometry pulling the rod.
P003A -16
this code means that there is an overshoot at the minimum limit of the opening when the rod is released which must not be less than 0.23% on the turbocharger control valve position sensor reader, engine off, and that rule with a bolt on the rod itself that allows to extend the rod or reduce its length
and of course I could do that thanks to Forscan
Learning the values ​​is purely physical with these bolts and threaded rod located on the turbocharger, with a visualization of the changes of the values ​​of the minimum and maximum positions on Forscan in real time.
thanks again Forscan
Posted: Fri Apr 12, 2019 5:06 pm
by Robdav99
P003A -16
That is very interesting. I've been getting p003A-16 recently from time to time.
Ive seen vane_pos go to 100.50% quite a few times, do you think that is what is causing it?
Can it be fixed just by winding the knurled threaded rod back on the actuator untill is no longer goes past 100%?
Posted: Tue Jul 16, 2019 6:48 am
by Mondeus87
Hello everyone,
I experience issues with P003A as well, however it is also connected to strange sound coming when I release acceleration pedal. Something like metallic sound, usually appears when i drive on 4th-5th gear and accelerating and releasing. Really strange.
Have any of you experienced similar and know how to deal with it ?
Thank You in advance !
Posted: Tue Jul 16, 2019 10:06 pm
by denbo
Some good reading here. The turbo vanes do get sticky. You can buy some good turbo cleaners and they do work. Its important to manually move the arm to free off the vanes while the cleaner does its job. Sometimes it may take 1 or 2 times depending on how gummed up the vanes are. If you take your time and do the job correctly the results are excellent. I have done many, and sometimes have to use oven cleaner for the more stubborn ones. In regards to metalic noises, if there from the turbo area, with the engine off, remove the rubber pipe from the turbo and stick your finger in to feel for any play in centre shaft. Even the smallest amount of play means the turbo is failing.
Posted: Tue Aug 06, 2019 1:50 pm
by daufmen
P003A -16
Hello there
First Excuse Me for the time that I have do answer, You know from the time I haven't conserved the forum I haven't received any email to inform me that there is message
After I want to confirm you that's your idea is very correct You have to Adjust them Us the method that you have say to don't pass 100%
For me I have put it in 99% or 98%
you will have to put a value a little lower than the maximum 100% because as soon as you start to tighten the wheel on the rod the values ​​change a little
But if you have this value 100.5% Constant But if it's change from the time to the time you have to find the problem is air pump
If it's not constante , you should have a problem in the circuit of vacuum sucked by the vacuum pump which also controls other systems like braking and butterflies that control the intake air volume
If its constant at 100.5 % , You have only to adjust Could have told And don't believe to adjust to the minimum at 1%
Posted: Mon Oct 14, 2019 5:12 pm
by jovanzac
Hello!
I have problem with my Mondeo. Vane position, when i start engine, goes to 103% and after 2 seconds drops to 99%. I do not have error P003A but what i have is annoing pulsing acceleration at 100% throttle between 1750-3000 rpm. Boost goes to 1.3 bar and then drops for a second to 1.1 and then goes to 2.3 again and again drops down etc until 3000 rpm. After 3000 rpm no more pulse acceleration. Is this due to wrong adjusted vane position sensor ? Should i adjust it to be 98% like you have wrote in your post ? Btw my Mondeo has egr and dpf off. Egr is blanked.
Thank you in advance!!!
Posted: Wed Oct 23, 2019 3:44 pm
by jorgemef
I have similar problem. Same Smax 2.0TDCI 140CV. 150.000 km on it.
What I did already:
Replaced vacuum regulator solenoid as small leak appeared with vacuum testing pump when solenoid was off for inspection. Cleaned turbo with hoven foam once. Cleaned EGR twice (EGR already had exhaust residuous on the rod handling mechanism 2 months after first cleanup) . Cleaned MAP sensor with carb cleaner/air. Cleaned air temperature sensor. Checked for boost leaks none found. Reset/reboot PCM (today).
The car makes black smoke on acceleration. Sometimes pulsating when cruising and long pulsation when accelerating. Not fully tested after PCM reset.
Goes into MIL when accelerating hard (uphill) for some time(2KM~2000RPM). Mostly if engine temperature gauge goes to middle(85ºC?). I need to stop the car before resuming trip so tubo function returns.
Codes thrown: P003A:17-68; P2263:73-68: Actuator stuck closed.
VGT settled around 102.4%
Readings after reset PCM and driving for 20 minutes:
APP; RPM; FRP; MAF; MAP; VANE_POS; EGRVP_V; EGRVR; EGR_ERR; EGR_PCT; EGR_TV; IAT2; IAT; ECT
Readings before reset on next post
Anything suspicious? Advices?
