Clear crash data from RCM
maddvector
Vehicle: 1996 Ford Mustang 3.8 L coupe
Post by maddvector » Wed Jan 11, 2017 10:58 pm
Do you plan on adding the ability to clear the crash data from the RCM. The code is B1193.
I work in a body shop and it would be nice if Forscan had this capability.
maddvector
Re: Clear crash data from RCM
Post by maddvector » Wed Jan 11, 2017 11:00 pm
The vehicle is a 2011 Ford Mustang 3.7 V6
dondilidon
Vehicle: Ford Fusion 2016
Post by dondilidon » Wed Jan 17, 2018 4:41 pm
This is interesting to me too...?
denbo
Vehicle: ford focus 16 zetec
Post by denbo » Wed Jan 17, 2018 7:45 pm
To remove crash data etc you need a completely different kind of tool. A programmer tool, and an experienced user is required.
tjjd90603
Vehicle: 2008 F350 6.4 turbodiesel
Post by tjjd90603 » Sat Jan 20, 2018 1:16 am
Once the ford rcm say crash databfull only way to use it again is eeprom , I intstall used f6893505ord rcms on wrecks all the time. Forscan is good to copy it and upload the asbuilt to the used one. But no zero weight test in forscan. We need pcm install with vin write capability, and zero weight test.
