throttle position
william
throttle position
Post by william » Wed Sep 03, 2014 3:53 pm
hi, the pid for intake air throttle position on my car gives a value (ct) when the car is at idle, a quick half snap of the accelerator and it changes to (pt) then back to (ct), a quick full snap of the accelerator and it changes to (wot) then back to (ct), I think the abbreviation (wot) is wide open throttle but I am not sure what (ct) and (pt) stand for. any info on the abbreviations much appreciated. thanks.
08 mk4 mondeo 2.0 140 bhp
09Ranger
Vehicle: Ranger, 2.3 Duatec, 2009
Re: throttle position
Post by 09Ranger » Thu Sep 04, 2014 11:49 pm
Closed Throttle
Part Throttle
Wide Open Throttle
william
Post by william » Fri Sep 05, 2014 4:30 pm
thinks for the reply, I am surprised the I was getting the value closed throttle when the car was at idle, I thought a would only see closed throttle when I switched the car off as the throttle valve is to prevent engine run on and shudder when engine switched off.
09Ranger
Post by 09Ranger » Fri Sep 05, 2014 10:16 pm
Whenever your foot is off the pedal, you're at closed throttle.
The idle is handled by the IAC (idle air control) valve.
Tony Back
Vehicle: Ford Focus
Post by Tony Back » Thu Sep 25, 2014 3:30 am
What's your vehicle model?
Google obd365 can find tool to get the throttle position adjusted.
And the problem will solved
:lol:
mradu2005
Vehicle: ford focus 2005
Post by mradu2005 » Fri Sep 26, 2014 5:07 pm
Hi and please to the future make some pictures whith forscan software and elm interface because we will see and learn mutch . 8-)
