Page 3 of 3
Re: Cleaning clogged DPF on Ford Focus II 1.6 TDCI
Posted: Sat Apr 28, 2018 9:35 am
by fordPT
I decided to share my experience, as I was able to solve my issue due to the first poster of this thread and the MAF trick.
I am not a mechanic at all and I did not had experience with any software or the OBD2.
Story: When driving on the highway I got "Engine failure". 125 000Km. Motor acted from that point forward as it did not had power, like no turbo was active. Uncomfortable with the idea of going to the mechanic again and spending a lot of money, I decided to try to know where the fault was. I ordered a ODB2 scanner, Bluetooth, that costed me about 15€. Came from one day to the other.
First thing that I did was to install a software that is called TORQUE (at that time I did not knew about ForScan), and the android application told me that I had the P242F fault. Reading about it, it was the particle filter that needed to be cleaned. Fault on the computer corresponds to "diesel particulate filter restriction ash accumulation".
I was unable to take the fault out and at that time I read about the FORScan application. I was able to connect to the car using my adaptor and a computer, so I started to understand how things work. First thing was to try to make a static filter regeneration, that failed all the time at about 11%.
The result was: Service procedure has been interrupted
I also took information about the DP_DPF (pressure in the filter), and at idle I got about 3KPa and at 2K RPM about 13KPa, others RPM's I did not tested. Values here high, but not the highest that I saw in the forum, so I though that I should try a static regeneration. At the same time more reading about the subject told me that with this error (P242F) the car thinks that the filter is over static regeneration possibility, then the only solution would be to remove and to clean the filter... I opened the hood, and damm, it looked a lot of work for someone as inexperienced as me. So I read this post about the MAF sensor, followed the procedure and I was able to take the P242F fault. After this I was able to run the static generation.
After the static regeneration I was able to test again the pressure values and I got about 0.7KPa at idle; about 3.6KPa at 2K RPM; 8KPa at 3K RPM and about 12KPa at more than 3.5K RPM, so a improvement was noticeable. I think I did it correctly. If the values are ok, I really do not know, so I unsure about how much time the car will run without the same problem.
I made videos during regeneration and after regeneration.
https://youtu.be/aaA7z6ZI3Qo
https://youtu.be/Nit6pjlteRY
During regeneration, no smoke was noticeable from the exhaust.
Now I am happy again... I just do not know for how long !
Posted: Tue Jul 31, 2018 2:35 pm
by lkola
Can you tell haw many minutes is the duration of the static regeneration, and can you share any update on behavior of DPf from the regeneration.
Posted: Mon Sep 03, 2018 12:26 am
by peterc
I flushed out my DPF without removing it.
I used Mannol 9995-9996-Diesel-Particular-Filter-DPF-Regenerator-Cleaner-and-Flush-Fluid-Pack.
I removed the Temperature Sensor and poured the cleaner through the hole using a small funnel and plastic tube then followed the instructions on the cans.
I took the car for a 20 minute drive on the motorway then cleared the code and reset the DPF regeneration. Car came out of limp mode and has been fine for about two months now :)
Posted: Wed Sep 19, 2018 7:38 am
by pietr
Does anyone know if the DPF on these cars can be removed when the car is on standard 3 ton jack stands? Or would I need a lift/pit?
Posted: Sun May 05, 2019 10:40 am
by Mareng
kramdrol wrote:
Mon Nov 13, 2017 12:20 am
Hey, 2015 mazda6 2.2 dt. Engine oil light regularly comes on. Oil level had always risen to the 'X'. WTF? Mechanic did not know what was going on. The internet helped me figure out it was automatic DPF regens while driving, causing oil to be diluted with diesel fuel. Seriously considered DPF removal as I only do small trips. More searching led me to buy a bluetooth OBD, a USB -> bluetooth for my laptop, and a few free programs to try. Only Forscan worked properly. Did a forced regen, took 45 minutes. Great program!!! Car now running much better. Am now monitoring the car while driving on the road using the Android version of forscan. I have 6 parameters I am monitoring. DPF_REG_CNT (regen count), DP_DPF (differential pressure, most likely reason for auto regen), OIL_DIL (oil dilution, set max level to 1kg, shows .1kg with oil level 1/4 of the way between 'full' and 'X', REG_DIS (distance since last regen), REG_REQ_A (request for regen auto), and REG_REQ_F (request for regen forced). Have done 120 ks since forced regen, all good so far. The DPF is clearly not fit for purpose, in regard to how it is cleaned automatically. Will ruin my engine with oil dilution if not monitored and cleaned properly with a forced regen. Will see how I go with the ability to monitor and force regens. Love the car otherwise!
UPDATE
After about 200km since forced regen, the DP_DPF pressure started climbing to often between 10 and 19. Soon the REG_REQ_A switched to 'on'. Everytime I stopped at lights it went back to OFF. When I took off it returned to ON. Luckily I had 20 mins spare so I hit the local freeway. 10 minutes of freeway driving and the regen went back to OFF. There has been no change in OIL_DIL or dipstick level. There was no indication that the car had gone into AUTO_REGEN other than the forscan utility. I wouldn't have had a clue otherwise.
So even though this 'worked' I am not wrapped I will have to do forced regens all the time, to avoid these unfinished auto regens and associated oil dilution. I only do small trips. This will always be a problem for me. The DPF leaves the car unfit for constant small trips, ruining an otherwise great car. DPF removal is really the only practical solution for me.
As an ownerof a 2014 M6 from new, I would recommend changing your oil and filter well before you reach the "X" on your dipstick. Normal oil change is 12k miles, try at 6k miles. These Skyactive diesels are not meant for running round the town all the time but for long motorway journeys, so I would suggest once a week take it for a steady drive at 70mph in 4th gear and cruise control on the motorway for at least an hour. Heavy accelleration will not help your cause.
There has also been a software update to the EGR during Autumn 2018, this should be followed by a dealer intake manifold and cylinder head decoke. Its a 2 day job in which the they remove the inlet mainfold, EGR and its cooler and decarbonise everything.
I certainly would not remove the DPF on your model as it is illegal and you will run into more problems. The car works fine if driven correctly.
I achieved 51mpg the other week and the car running very smooth and responsive . Are you using a C1 engine oil?
Posted: Mon Sep 09, 2019 9:14 am
by auskuba
I high pressure hosed my dpf on my 2008 ma mondeo tdci and it worked after a forced dpf regen.
Thanks heaps for this thread.
Posted: Sun Dec 01, 2019 3:26 pm
by Mareng
If you carry out a forced Regen then change the oil and filter before driving the car, there has been enough troubles with the Gen 1& 2 2.2d Mazdas and the early Gen 3's with sludge in the sump and badly worn camshafts.
The Skyactive 2.2d's are not designed for total town driving, poor design on Mazda's part but we have to live with it. You really need to give it a long hot run on the motorway frequently, without changing gear once the regen starts. This is indicated when the instantaneous fuel consumption drops from say 60+ to 20-30 mpg without any change in road conditions like hills.
My regens are every 40 miles these days when they should be 100 miles.
Come the warmer weather I will be removing the DPF and flushing it through with soapy water as this disolves carbon then rinsing with a hose and fresh water. No doubt a regen does not clean the DPF completely, so over the years there is a build up.
Posted: Wed Jul 22, 2020 12:59 pm
by tallrob
Ford 2.0 tdci, P242F blocked dpf...
Wife driving on the highway suddenly limp mode, "engine failure" and engine light. She calls roadside assistance and they come out like a race car pit crew and spray brake cleaner in the air filter while revving to 4k rpms. Of course they still can't clear the error bc they don't know squat about Fords. Did they clear the blockage? Did they do more harm than good? Who knows. They just told her, "next time buy a petrol, diesels are only for long drives". I call bull. There are plenty of diesels on the street that do just fine with short and long mixed driving. This problem is 100% purely with the Ford notification system, wherein a partially blocked dpf and failing egr don't show an error at all, until it's too late.
So anyway, I know I have a stuck open egr valve now, and my dpf pressure readings are low enough after the brake cleaner treatment given by my pit crew boys. Decision now is whether to remove egr and dpf myself and clean them, or have a garage do the egr and ask if they would dare clean the dpf (or just remove it and let me take a soapy hose to it). I don't have lots of time, but seriously have no cash to throw at maybes.
I'm cautious about continued strain on the engine by doing the MAF trick to clear the dtcs. But maybe that's the only way to really see if anything has changed, or if I still have a blockage. EGR has to have some attention I think (though maybe the brake cleaner took care of that too).
Thoughts?
