ford transit year 2000
biskety
Vehicle: transit 2.4 td
Post by biskety »
Adapter: ELM327 v1.5
Min.delay: 3 ms ( Excellent)
Errors:
- CAN ERROR: 3 ( 1.0% )
Vehicle:
Model: Ford Transit
Engine: DURATORQ_DI
Capacity: 2.4L
Year: 2010
Generation: 2000 MY
Fuel: Diesel
VIN: WFxxxxxxxxxx39266
PCM - Powertrain Control Module
Part number: 1C1ANE
Strategy : PUPIAJ5
Calibration: 1C1A-12K532-ABC
Copyright Ford Motor Co. 2000
FIP - Fuel Injection Pump
CSM - Security module
Part number: YC1T-15K600-DA
Software version: v13 1999-10-09
RCM - Restraint Control Module
Part number: YC1AAE
Software version: v6 1999-09-07
fitted new chain kit but wont clear fault also is the engine 2010 or 2000
===PCM DTC P1664===
Code: P1664 - FIP malfunction
FIP malfunction
FIP timing chain tension
PCM
This DTC may be caused by :
PCM
FIP
===END PCM DTC P1664===
===PCM DTC P1564===
Code: P1564 - FIP requesting reduced fuelling mode
The FIP has identified a fault that may cause damage to the engine
If any other DTCs are present address these first.
===END PCM DTC P1564===
===PCM DTC B2141===
Code: B2141 - There is no PCM identification known to the PATS module.
NOTE: The PATS module functionality can be integrated into various modules. (See the Module I.D. tagged to the DTC.)
--- Possible Causes --------
NVM configuration failure
Non Volatile Memory option content checksum not correct
-Suspect ECS Module not configured for vehicle application
===END PCM DTC B2141===
===CSM DTC None===
Successful DTC reading, no error codes found
Module: Security module
===END CSM DTC None===
===RCM DTC None===
===END RCM DTC None===
P1664, P1564, B2139, B2141 what would be the best next step to sort this out please
biskety
Re: ford transit year 2000
Post by biskety »
:D Fixed at last all ok now working well
by biskety » Wed Jul 20, 2016 8:57 am
And it took that many years?
psml1
Vehicle: ford transit mk6 2005
Post by psml1 »
biskety wrote:
Fri Jun 11, 2021 7:52 am
what was the fault you managed to fix with error B2139
biskety
Post by biskety »
it was a long job but i was still using it but was very slow ,after 2 injector pumps 3 ecu and 2 complete wiring looms i gave up ,and got my self a complete working van(waned lots welding ) and swapped everything over everything it was a identical van same year same engine a 120 bhp x BR welfare van and used forscan to do ecu and keys and injector pumps
Code: B2141 is ecu not finding the injector pump
psml1
Post by psml1 »
i only get B2139 i dont get B2141
engine still starts no problem
i get imobiliser light flashing on the dash
when you changed pump did forscan reprogram the pump to the van
