DPF regeneration fault
silvercircle
Vehicle: Ford Focus 2.0 TDCI Powershift 2009
Post by silvercircle » Mon Aug 25, 2014 5:32 pm
i tried to start manually Regeneration on my Ford Focus 2.0 TDCI Year 2009 with powershift gearbox.
the Regeneration started normaly but when the rpm goes to 3000 Umin, stoped the Regeneration with
an error and the Information "kontakt the programmer".
then i tried the same Prozedur bei my friends car, it is a Ford Kuga 2.0 TDCI mk1 year 2008, here started
the Prozedur without an error, but the rpm doesnt go to 3000 rpm. the car works 20 minutes with Standing gas.
is any Body here and can help me.
thanks
Thomas
Re: DPF regeneration fault
Post by FORScan » Wed Aug 27, 2014 5:09 pm
silvercircle wrote:Hello,
Can you please send us FORScan logs as instructed here by email or PM?
silvercircle wrote: then i tried the same Prozedur bei my friends car, it is a Ford Kuga 2.0 TDCI mk1 year 2008, here started
Behaviour is different because procedures are different (almost every platform has its own version). It is weird RPM weren't increased. What was the result of the procedure regeneration on Kuga?
silvercircle
Post by silvercircle » Sat Aug 30, 2014 2:39 pm
thank you for your answer. i didn´t find your email, pm doesn´t work. so i can not send the Protokoll.
i post it here in the Forum.
today i tried to activate the Regeneration process at once. in the Laptop goes the time from 0 to 20 minutes, and there is no Regeneration of the dpf.
when i start the procedure manually, i give gas with the gaspedal up to 3000 rpm, and wait until the regenaration is ready, after 20 min. the dpf is cleaned.
the pressure in dpf ist in stand gas is 0 and goes up to 240 when i drive.
i hope it is o.k so.
thanks
thomas
carlus
Post by carlus » Sat Aug 30, 2014 4:04 pm
Procedure for sending log --> http://forscan.org/contactus.html
A greatting
MAZDA cx7 diesel
Post by FORScan » Mon Sep 01, 2014 11:34 am
silvercircle wrote:thank you for your answer. i didn´t find your email, pm doesn´t work. so i can not send the Protokoll.
PM doesn't work for newly registered users (require 3 posts before sift to Normal User group). We have removed this limit for new users, however old users may still experience the issue. In this case, please send information by email using instruction on the site as mentioend by carlus.
wifiuk
Vehicle: Ford Focus TDCi 1.6L 2007 Ghia
Post by wifiuk » Wed Sep 03, 2014 12:06 pm
i did a static regen on my 2007 Ford Focus TDCi 1.6L Ghia today and it worked fine.
Post by FORScan » Sat Sep 06, 2014 2:09 am
Status update on this issue:
According to the logs sent by silvercircle (thanks for it, btw), found few bugs in DPF static regen procedure for Focus Mk2 since 2008 with Powershift transmission (some modifications), and also noticed a small problem that might cause unsuccessful start of the regeneration on Kuga 2008 Euro 4. Both issues are resolved, the fixes will be available in next FORScan release (2.1.20 or 2.2.0, what will be released earlier). If anyone need these fixes and cannot wait for next release, please email or PM us and we will provide a test build.
rplc1976
Vehicle: Ford Kuga 2010 X
Post by rplc1976 » Sat Jan 03, 2015 5:26 pm
Hi
The static regen for my 2010 Uk Kuga isn't working. It just sits at idle... :-(
Please help.
Robin
Post by FORScan » Sun Jan 04, 2015 6:08 am
Please email us internal FORScan logs as described on Contact Us page.
rplc1976
Post by rplc1976 » Sun Jan 04, 2015 4:16 pm
Thanks will do.
Do I need to fault codes cleared before the regen? The problem is, when I clear them, they come back within minutes and Im wondering if this is causing problems with the regen starting?
