WARN
dennis7d
Vehicle: Fusion Hybrid, 2010
WARN
Post by dennis7d » Sat Aug 23, 2014 2:52 am
Hello, I just used this software for the first time on my car. 2010 Ford Fusion Hybrid. I received these Warn codes
DTCs in PSCM: U0415:00-08
DTCs in IPC: B10D7:8F-28
Any help with what these mean?
Also is there any way to get the code for the key-less entry?
Re: WARN
Post by FORScan » Sat Aug 23, 2014 9:18 am
dennis7d wrote:DTCs in IPC: B10D7:8F-28
Unfortunately, our database doesn't contain detailed description for this DTC. Our opinion is that it means one of ignition keys is not always detected stable.
dennis7d wrote:DTCs in PSCM: U0415:00-08
FORScan should return description for this DTC - Invalid data received from ABS module. Uxxxx codes are bus errors and considered to be not criticial for CAN vehicles. It may be caused by work of a diagnostic equipment (in your case - ELM327 + FORScan).
dennis7d wrote: Also is there any way to get the code for the key-less entry?
No.
