about ECU's info
jonny
Vehicle: Ford Ka - insigma 1.5 flex - year 2013 -
about ECU's info
Post by jonny » Sun May 22, 2016 3:00 pm
Hí ForScan admin ,
About ECU info in Forscan Software, is possible read ECU information of each module ? see example below :
RCM (airbag) module info ID ( tested with another scantool )
VIN: 8AFAR24L7EJ2620764
File name : DB39-14CO94-BB
part number : DB39-14A073-BB
calibration : DB39-14C095-BB
serial : 657001963874
Is possible add this feature in next, or future release ?
many thanks.
Automate
Re: about ECU's info
Post by Automate » Sun May 22, 2016 3:12 pm
jonny wrote:tested with another scantool
Which software showed you these values?
jonny
Post by jonny » Sun May 22, 2016 3:27 pm
Autocom 2014.3 ,Delphi Group (Software Sweden )
Automate
Post by Automate » Fri Jun 03, 2016 7:23 pm
FORScan does show some of that information
I have noticed FoCCCus also shows the hardware version of the module which FORScan does not show
HW Number.PNG (40.39 KiB) Viewed 2508 times
