Ford Mondeo Auto Door Lock
- Vehicle: Ford Mondeo, 1.8tdci, 2008
It's possible to enable the Auto Door Lock with FORScan?
Best Regards,
Marco Gaspar
Best Regards,
Marco Gaspar
Re: Ford Mondeo Auto Door Lock
If you are asking about Mondeo Mk 4, it is possible only via Central Configuration (CC). CC function in Mondeo Mk4 is being developed now.
Yes it's for Mondeo MK4.FORScan wrote:If you are asking about Mondeo Mk 4, it is possible only via Central Configuration (CC). CC function in Mondeo Mk4 is being developed now.
When it would be possible?
Best Regards,
Marco Gaspar
We are hopeful it will be available in one of nearest releases.
- Vehicle: Mondeo MK5 1.6l Ecoboost
It is possible to activate Auto Door Lock on the Ford Mondeo MK-5?
As far as we know, Mondeo Mk5 has no CC, so it should be available via AB. Unfortunately we have no decoding for this (and majority of others) option, so it is only available in raw AB format yet.
Yes is possible
Auto lock motion:
IPC
720-01-01 0466 F464 6A55
to
720-01-01 0467 F464 6A56
BCM:
726-15-01 0202 0202 024D
to
726-15-01 0101 0101 0148
In my Mondeo HEV work fine
Thks Ben !!!
Regards from Spain
Chema
Auto lock motion:
IPC
to
BCM:
to
Thks Ben !!!
Regards from Spain
Chema
A little bit off topic but does anybody know the bit codes for the power folding mirror on the DDM and PDM?
delayed folding out mirrors:
DDM 740-03-01 set bit 9, counting the bits from left to right, beginning with zero. So from left the second bit in the second byte.
- Vehicle: Mondeo 2.5t 2007
Hi, just to be sure, if I set the second bit in the second byte of DDM 740-03-01 the out mirrors auto folds when locking the doors?... if so, setting this bit acts on both mirrors on both sides?AmigaSurfer wrote:delayed folding out mirrors:
If all the answers to my questions are YES... PLEASE!.. tell me how to do it (tell me what I need to know or read to learn how to achieve it)
Because I am a newbie here and there's a lot of info to read and learn
If you know how direct me where to learn about this!!!
Thank you!
Regards!
