transit 2015 2.2 155ps static regen temp too high
arensirb
Vehicle: 2015 Transit 2.2Tdci 155hp
Post by arensirb »
Hey guys.
I just changed the thermostat today to fix the first issue I had.
Now I have exhaust temp sensor bank 1 sensor 4 showing -40 degrees and the static regen says exhaust temperature too high.
Is there anything I can reset to try to make this work? I can't find a sensor 4. I unplugged all exhaust sensors and only found the one that was the black wire.
Any suggestions?
Re: transit 2015 2.2 155ps static regen temp too high
Sensor 4 does not exist.
Post your scan with the strategies, fault codes and the controllers list using the Modules Tab.
Use this tool to capture screen images.
Snipping Tool.JPG (63.81 KiB) Viewed 65 times
