Cold start - engine vibrations, changing RPM - what to check
AdvTechTS
Vehicle: Ford Focus LT TDCi 2.0L
Re: Cold start - engine vibrations, changing RPM - what to c
Post by AdvTechTS » Sun Jan 17, 2016 5:01 pm
Hi, is your car fixed now?
I had very similar problem with a Ford Focus with the same engine it had the following cylinder contributions
before injector was replaced
IMAGEDATA_FOCUS_PCM(PowerTrain Control Module)_DAT_0003.jpg (122.06 KiB) Viewed 3305 times
I then checked the back leakage and found that #3 was excessive (others were good).
back leakage
back leakage 2016-01-11_hot_lowres.jpg (401.53 KiB) Viewed 3305 times
I replaced Injector #3, car is now perfect.
after injector was replaced
IMAGEDATA_FOCUS_PCM(PowerTrain Control Module)_DAT_0008.jpg (167.07 KiB) Viewed 3305 times
You need to remember that cylinder contribution is purely looking at crankshaft spend in correlation with injection at idle,
if your injector #1 dribbles fuel it could cause a pre-ignition (knock) and then accelerate that piston (hence the 1.40 contribution).
Diesel engines are always lean, any extra fuel will cause an increase in speed and because one cylinder is accelerating the PCM must stall others in order to maintain the desired RPM (otherwise you will have a runaway engine).
rmkk
Vehicle: Mondeo 2007/2.0TDCi/103kW, Focus 2006/1.6TDCi/66kW
Post by rmkk » Sun Jan 24, 2016 11:18 pm
Hi, thanks for posting Your case, because it gives me a hope for such easy solution.
Anyway, my car is not fixed yet. I'm waiting for my service to fix another car and makes a room in garage to replace injectors in mine. New injectors was already delivered to service.
Today I made a live data record of idle engine, relatively warm at 19C. Interesting is, that after blinding a EGR, there is still a hunting of engine probably caused by EGR. It is something I cannot understand. I'm posting part of diagram where EGRVP_V reguraly opens/closes what increases a load and it makes a shakes of engine and all the car. If somebody has an idea how to explain it, please let me know.
stojanhu1981
Vehicle: mondeo 1.8 tdci 130hp 2007
Post by stojanhu1981 » Fri Nov 18, 2016 11:45 am
Hi.
Did you solve the problem? I se you have high fuel pressure (460 bar). On idle must be 300+-10 bar, when cold 360bar(360 kpa). Did you check glowplugs, IAT sensor? I also have an issue with cylinder balaces on mondeo 2007, 1.8 tdci (330.000 km on clock), but i didn't notice any starting/driving problems. The only thing is that i can't drive under 1800rpm in 3rd uphill. I have balances cyl.= 0.8, cyl.= 1,cyl.= 1.3, cyl.= 0.8. They fluctuate up and down. I replaced reconditioned injector on cyl. 3 but stil the same. After that replaced ultrasonic cleaned injector from cyl. 3 to cyl. 1-still the same, so i gived up. The slight improvement i noticed when i used lubricating and cleaning additive from bosh specialist. (http://www.motornaolja.com/produkt/dize ... ppante-25/).
Description : additive for Common rail cars with/without DPF. It lubricates an cleanes injectors and pump, reduces smoke. For lubrication 0,1lt on 50lt of diesel, for cleaner hole botlle on 5 lt of diesel.
Stojan
hojland
Vehicle: Ford mondeo tdci 2.0 2010
Post by hojland » Tue Jan 16, 2018 3:08 pm
Have you fixed the problem. Mine dos the same
denbo
Vehicle: ford focus 16 zetec
Post by denbo » Tue Jan 16, 2018 8:13 pm
On the mondeo mk4 i will only fit NEW. Always get problems with rebuilt ones sooner or later.
