ST170
Re: ST170
"So the possible causes of P1000 could be: battery disconnected - did that few weeks ago and i have been driving a lot.
PCM Diagnostic Trouble Codes (DTC) have recently been cleared with a scan tool - 4 days ago, so maybe this could be the problem"
Yes 100 %. The PCM will store the emissions test for that day. Disconnecting the battery (you noticed) may reset the clock and those PCM values. Depending on the vehicle, the radio presets will return. Those are stored within the radio eeprom.
Sometimes the electric window "one trip up, one trip down" require a reset.
Replacing the battery is a reasonable explanation.
TadeasFord
Vehicle: Focus ST170 2002
Re: ST170
Post by TadeasFord »
Thank you very much.
TadeasFord
Re: ST170
Hello, so P1000 disappeared, but i still have CAN error, so i am not able to go to all modules. I tried it on different car (focus mk2) and it worked perfectly... Is focus mk1 supported?
Pictures...
Re: ST170
2002 Ford Focus ZETEC ST
Diagnostics is PWM J1850 and ISO
The model does not support CAN
The scan tool is looking for CAN and in that model and CAN does not exist.
You should find a workshop manual and read about that model.
The Focus mk1 and Focus mk2 are completely different models.
TadeasFord
Re: ST170
Thank you for answer, so i need scan tool which is compatible with mk1
Re: ST170
The model you just tested is a MK1? The images are from that MK1?
TadeasFord
Re: ST170
Yes, that is MK1.
Re: ST170
TadeasFord wrote:
Fri May 28, 2021 9:21 am
Yes, that is MK1.
There is nothing wrong with the adapter.
Diagnostics is PWM J1850 and ISO = Pulse Width Modulation
The model does not support CAN = The diagnostic protocol is PWM with ISO
Look at the diagnostic adapter, PINs 6 and 14 are likely non existent.
TadeasFord
Re: ST170
Thank you very much! I will try to find J1850PWM
Re: ST170
You still don't understand!
There is likely no problem with the adapter you have.
Read this!
https://obdstation.com/obd2-protocols/
The protocols are just a "language". The adapter is an interpreter.
The adapter will speak English, French, Italian, Russian, Spanish, German, Chinese, Portuguese, Arabic, Polish, Uzbek, Czech and so on.
Good quality ELM327 devices speak ALL the languages.
