Ford f150 2018 engine and drl on the same time engaged.
Dirk Bode
Vehicle: Ford F150 5.0 2018
Post by Dirk Bode »
Is it possible to program with forscan: when the engine is fired up the drl are on in the same time!
I need this function because of the law in Belgium !
Thanks in advance !
Re: Ford f150 2018 engine and drl on the same time engaged.
Providing no one hacked the harness or removed the fuses:
2018 Ford F150 enable DRL
Number 1, SAVE the original As-Built data and name it.
Number 2, You are responsible, not me and not this site.
DRL - Parking Lights and stock LED's (no information was provided)
BCM 726-26-02 x1xx xxxx xxxx
BCM 726-50-01 01xx
With FORScan, the controller that needs changes is the BCM = BdyCM
Anything in the lower case x is to be ignored.
All other digits are the ones to change.
Save the new values and exit FORScan.
Cycle the key to OFF and then start the engine.
The headlamp switch needs to be in the Auto Position at all times.
The F150 needs to be in Drive for the DRL's to operate.
Post your results with the before and after scans.
Dirk Bode
Post by Dirk Bode »
The Lights must be on when the truck is also parked with the engine on!
