How to check blank PATS key
raven1783
Vehicle: Ford, 3.6 eco boost ,2014
Re: How to check blank PATS key
Post by raven1783 »
eroark79 wrote:
Tue Mar 05, 2019 1:32 am
I am getting codes B10D7:05-48 and B10D7:51-08 on the key when trying to program a new key to the ignition of my 2014 F150.
B10D7:05-48 System programming Failures
B10D7:51-08 Not Programmed
What can be done. I was able to successfully get the Fob paired with the truck to where I can remote start the truck but cannot get the key to program
I have the same issue when trying to program my new key to my truck “2014 f150” fob pairs just fine but the key won’t programe I get “started system fault”. I still need to check the code on it with FORScan.
Have you had any success with your key programming?
metty2k
Vehicle: F150 XLT, 5.0 2014
Post by metty2k »
I also have the same problem with my '14 F150 XLT 5.0.
Dealership only gave me one key when I bought it 3 weeks ago. I can't get the 2 i purchased to program. Did you have any luck?
raven1783
Post by raven1783 »
Unfortunately I found out that the chip inside the new key I bought wasn’t any good so I returned it and got a new one. After I got the new it paired just fine
raven1783
Post by raven1783 »
metty2k wrote:
Fri Apr 12, 2019 9:03 am
Forgot to mention that you can also buy the chip separately and insert it to the new one that’s not working it’s like 5$ on eBay not sure about amazon this the one mine has
This is the part number my aftermarket chip has
145-FO
4CA1EVG
metty2k
Post by metty2k »
Thanks, I ordered 2 standard OEM ignition keys with transmitters in the key head(without the FOB). My system says there are 3 Admin keys, I wonder if one isn't the Astrostart fob? I was able too use that plus the key I have to get into program mode to program the 2 keys with FOBs on them to synch, but only the FOBs.
raven1783
Post by raven1783 »
metty2k wrote:
Fri Apr 12, 2019 10:56 pm
Is it fobs or keys with built in fobs?
metty2k
Post by metty2k »
Keys with built in fobs. I did end up finding OEM Ford keys 2 for $24 on Amazon without fobs(jewel style). Had one cut and I programmed it at home using FORscan. Works perfect. The 2 key rule only applies to doing it manually. As long you have 2 keys programmed in Pat's, you can program a new key using one original(to gain access to PATS).
raven1783
Post by raven1783 »
metty2k wrote:
Tue Apr 16, 2019 10:50 pm
Right, now if you want to program the fob from the other key just turn the key to the run position 8 times the doors will lock and unlock to indicate that you are in programming mode then just click the buttons on the fobs so the system can learn them.
roko1234
Vehicle: Ford Fusion
Post by roko1234 »
Hello, I have a Ford Fusion USA 2016 year wants to program a new key but in modules I do not have PATS (forscan extended version 2.3.17, interface vscan stn1170 elm327v3) deleted profiles, I changed the version of forscan nothing helps how to turn module pats? Help.
billmnfl
Vehicle: 2016 Ford Transit Connect XLT LWB
Post by billmnfl »
Hi All,
I have just purchased a 2016 Ford Transit Connect XLT LWB.
The VIN tells me it was made in Spain.
There are two admin keys programmed into the Van, but only one came with the Van.
I purchased a new key and had it cut for $40,
I did the "How to check blank PATS key" and did receive the following DTC:
DTCs in BdyCM: B10D7:51-2F
There is only one active key and one blank key.
Shall I try it or what is the significance of the 2F in the B10D7:51-2F?
Should I trust it and go ahead an erase the two keys and reprogram or pay the local locksmith to do it?
Thanks.
Bill
