1.6 Tdci boost control solenoid
Wod
Vehicle: Ford Fiesta 1.6 tdci
Post by Wod » Tue Jul 14, 2015 10:45 pm
Hello there, can you advise if there is a way to test the boost control solenoid?
Or do I have to do this manually with a vaccum gauge?
Is there any way to find what the pressure should be at idle for example?
It seems there is more turbo lag and more turbo noise now for a few seconds and I'm lost
Any help appreciated
Cheers for the great work!
Re: 1.6 Tdci boost control solenoid
Post by FORScan » Wed Jul 15, 2015 3:37 am
You can check pressure using MAP PID.
At idle : ~100 kpa (1 bar) - atm pressure
Full load: ~230 kpa (2.3 bar) - 1 bar atm + 1.3 bar turbocharger
(not sure about exact value of max pressure for your specific engine).
Wod
Post by Wod » Wed Jul 15, 2015 12:24 pm
FORScan wrote:You can check pressure using MAP PID.
Hello, what I mean is that the turbo is hesitating. And I was wondering if their is an option to test the control solenoid which feeds vaccum pressure to the actuator? Lexia an pp wont work but they have test for the 1.6 hdi
Post by FORScan » Fri Jul 17, 2015 3:27 am
We don't know a way to check the turbocharger bypass valve on Fiesta Mk7 TDCi. The PID is not available, only variable geometry duty cycle can be read.
donate
Vehicle: Mazda 3 1.6 CRTD Y6 DPF 109 HP, 2007
Post by donate » Mon Nov 21, 2016 5:23 pm
Hi, i was trying to do exactly this in Mazda 3 1.6 (same motor). I supposed that KOER should test the solenoid, and could confirm it simply looking the neumatic actuator near the turbo.
But KOER doesn´t work in my Mazda. Don´t know why.
