PDM and DDM false error
Posted: Mon May 11, 2020 12:14 am
by fasot
Hi:
Ford Ranger XLT 3.2 4x4 AT 2018
Always fails at PDM (B12FF:15-0A) and DDM (B12FF:15-0A) doors light sensors, but they are perfectly working.
Do you have any possible answer ?
error 1.PNG (121.76 KiB) Viewed 655 times
The attachment error 1.PNG is no longer available
Re: PDM and DDM false error
Posted: Mon Jun 14, 2021 11:25 am
by Jorge2311
I'm having the same issue.
I can't find almost nothing about it, but I don't know how ended in this page
http://www.alldump.net/wp-content/uploa ... 2015526294
According to this, the problem seems to be a high current drawn on the power window. In my case, the problem started after I tinted the windows, so I think it's probably the motor of the power windows taking extra current
In my case, it's just the 2 windows where I noticed the glass to move slower than the others
Hope this helps you
Tengo el mismo probema.
Casi no pude encontrar nada pero no estoy muy seguro de como encontré la página que puse mas arriba
Aparentemente el problema sería el motor del levantavidrio consumiendo de mas. En mi caso aparecio después de polarizar las ventanillas por lo que puede ser el motor del levantavidrio consumiendo de mas.
Se da justo en las puertas que noto que sube lento.
Espero te sirva
