Code
vhudsonv
Vehicle: Mondeo 140BHP TDCI 2.0 2007
Code
Post by vhudsonv » Tue Jan 28, 2020 6:25 pm
Hi anyone had this problem....Where to start?
Mondeo mk4 2007 2.0 TDCI Duratorq thought this engine didn't have a MAP sensor!!
===PCM DTC P2263:16-2D===
Code: P2263 - Turbo / Super Charge Boost System Performance
Additional Fault Symptom:
- Circuit Voltage Below Threshold
Status:
Module: Powertrain Control Module
Diagnostic Trouble Code details
Possible causes :
An electrical fault in the Turbocharger control circuit.
MAP sensor electrical failure.
Inspect connectors for signs of damage, water ingress, corrosion, etc.
If the code is set at idle renew the turbocharger. If the code is not set at idle investigate faults with the MAP.
