2012 Ford Focus PCM/ECM replacement and PAT's parameter reset
jwillman
Vehicle: 2010 Ford F150
Post by jwillman » Fri Nov 22, 2019 3:34 pm
I am running v2.3.26 with extended license and a HS/MS CAN compatible adapter.
My son had a mishap and took out the ECM/PCM and some wiring. I got a refurbed pre-programmed (VIN) PCM and new wiring harnesses and have it back together.
According to what I have read the PAT's system requires a "parameter reset" because the ECU/PCM was replaced.
I used Forscan to erase old keys and reload original ford keys. Forscan shows 2 keys loaded. I see a "module initialization" function under PAT's. Is that Forscan speak for "parameter reset"?
Right now the keys will energize the car but no crank in the start position and no dash indication of security issues.
I have no check engine light and the PCM, TCM, BCM and IPC all test good with sole exception of a lamp off IPC code of U0140 about BCM communication lost.
jeff2073
Vehicle: LW Titanium Focus 2.0i 125km 2012
Re: 2012 Ford Focus PCM/ECM replacement and PAT's parameter reset
Post by jeff2073 » Sun Mar 08, 2020 8:05 am
I have a similar problem.
Did you get a fix for this issue?
